OK, I have been helping a friend of mine with his 94' GT and I am at a bit of a dead end.The car dosen't idle very well and when you take it and drive it seems a bit doggy.
Only mods to the car are ported stock heads, trick flow stg 1 cam, and C&L M/A meter. We just replaced the distributor (it died during the rebuild process) it was installed correctly and timed right. We have pulled off the IAC and cleaned along with a new TPS.
One odd thing about the TPS, the old one was WAY below specs and at WOT would barely read over 1 volt. The new one, is doing the SAME THING, very low idle voltage and very low WOT voltage. I am thinking this is the problem but have no clue why we can't get more voltage out of it........
Any ideas????
Any ideas????
was the reading at the tps or at the computer? maybe the new tps is also bad?
