Ive got full exhaust, under drive pulleys, cold air intake, 75mm throttle body and EGR, electric fan and am adding a trick flow street burner intake was wondering if i should change my 19lb injectors to 24 while im in there or if the 19's are fine.
Yeah. All you've really done is change the intake and that isn't much. You usually only start worrying about the injectors if you change the heads, intake and cam.
