I dont know if I was supposed to do it in a certain order, or not? And Im not sure if this is the right way the cylinders go for you to understand which is which cylinder, but Ill try. If Im reading it right according to Haynes
Cylinder#1 is passenger side farthest away from firewall then 2, 3, 4. 4 being passenger side at the fire wall
Then cylinder#5 is drivers side farthest from firewall then 6, 7, 8. 8 being at firewall
CORRECT?
I did these with cold engine, WOT AND NO CERTAIN ORDER, if it matters?? I did not add any oil. I will try again tomorrow in the day light maybe not raining in a certain order wet and dry
I also was doing this alone so I couldnt see the valve on each turn over until I was done. I read your supposed to see how each stroke compressions strength is building. If it starts weak and builds up
(LOW COMPRESSION ON 1ST STROKE, FOLLOWED BY GRADUALLY INCREASING PRESSURE ON SUCCESSIVE STROKES INDICATES WORN PISTONS RINGS. A LOW COMPRESSION ON FIRST STROKE WHICH DOES NOT BUILD UP DURING SUCCESSIVE STROKES INDICATES LEAKING VALVES, OR A BLOWN HEAD GASKET, OR A CRACKED HEAD)
#1 was 130 psi
#2 was 130 psi
#3 was 125 psi
#4 was 130 psi
#5 was still at 65
#6 was 125
#7 was 125
#8 was 110, but it may have been b/c I couldn't really get the hose on the adapter very good. ALSO I think this drained my battery. HAynes says to do if for 4 strokes. I let it do it a for maybe 10 secs lol I read it online in a how to manual on porches
edit:says I should have a leak down test done if pressure is way down or varies greatly between cylinders.
So would 130 125 and the 110 be great difference in these? I know that cylinder 5 is, which could be a bad exhaust valve? Which is a valve in engine, or EGR?
CORRECT?
#1 was 130 psi
#2 was 130 psi
#3 was 125 psi
#4 was 130 psi
#5 was still at 65
#6 was 125
#7 was 125
