blksn955.o
Stock maf is a 70mm with a divide in the middle. The thing to look at is the flow rate, and the factory 94-95 maf is on the low end and IIRC less than a 65 Pro-M/PMAS flow rate. One needs to log and see were they fit if they are pegging a maf out, its the only way to know for sure. I would assume the combo in question would peg the stock 94-95 meter.
If one has a tuner like QH or tweecer R/T I would look for a factory Ford MAF or the SCT MAF that has 30pt transfers like stock. Then I would look at a Pro-M/PMAS not because its a bad maf just the others are going to be a little easier to tune since you dont have to convert a 10pt transfer with the Pro-M/PMAS to 30pt. Its not that hard to convert a 10pt to 30pt but if you can skip that step...one less thing. Then there is the "cheat" for the injectors and if one ever changes injectors things can get funky quick unless you send it back and the further you get from the stock inj. the bigger the chance you will be sorting out a driveability issue somewhere on our load based setups.
