cam upgrade
While I don't care for alphabet cams :)
One thing to keep in mind is .........
those cams were built to crutch up the piss poor e ports of OEM heads
therefore
It would seem to me that ...........
e cam would be more suited to be used with E7's than a TFS 1 cam that
was built for heads that do not have the same short comming as
old OEM iron heads
Just a thought :shrug:
Grady
There old single grind cams. They were designed to give old SBFs that classic grumbling noise. I'd also like to add that a .542 lift cam is likely to have piston to valve clearance issues without notching the pistons.
Kurt
Thanks for the info... was curious myself. I had been kicking around the idea of e303 for my E7's, but I think I am just going to leave the vert alone in that dept. If anything I do like the idea of the 1.7's. Would the rockers upgrade be noticable in terms of hp gain, or minimal?
My current setup:
3.73's
Cobra upper / .5" spacer / lower
70mm TB
Cold air
Shorty headers
Pro Chamber
Pro Dumps
Thanks,
Ben
10 rwhp isn't bad considering it's a 1 hour swap, and the rockers are something you're going to need eventually anyway. A cat back is only like 10rwhp, and that takes half a day to install, and costs twice as much.
Kurt
