I am planning on upgrading the front and rear brakes on my '65 to either the '05 Gt or the Cobra set-up. Aside from the most obvious difference in rotor size, 12.5" vs 13", what are the pro's and cons of either set-up.
I know the cobra calipers are basically the same as the C4 corvette. At a quick glance the GT's seem similar to the C5 corvette calipers. And if that is the case then the brake pads on the GT's should be significantly larger then the cobras, which I would consider a huge benefit, i just have no up close experience with the GT's to compare.
Anyones thoughts?
Anyones thoughts?
