Is it something that is bad enough that you'll change it down the road?
Would i like to change it? Yes, on principle alone.
Do i need to change it? Probably not. The situations it caused are taken care of.
Will i change it? If i do, it won't be for a while.
I would change it now during the oil pan swap, but i'm not up to spending another grand right now, with a pending house purchase.
The part that really pisses me off is that they knew i got it at jegs, 2 years before the issue, they knew i never used it, and they knew they screwed it up, yet didn't stand by it by giving me a new updated one. These projects take some time, so it was out of warranty before i ever even touched it.
Then they tell me they have parts to fix it, they will go out immediately, i call a week later and they didn't ship them. Then they come another week later.
On top of that the parts they sent didn't fit properly and had to be modified yet again.
To make it worse the lower cross bar was too high, so the rack hit the pan (even after the parts came that were supposed to fix that), so i had to use offset rack bushings reversed, which in turn make the tie rods too angled, so now i needed an outer bumpsteer kit.
Domino effect.
