I've been gathering up parts to do an HCI swap on my 91, however the car has always used oil. Doesn't leak, doesn't smoke when it ides. I had a plugged up PCV system until a couple months ago that was forcing oil into the throttle body. I assumed that was the cause of my oil loss, but I checked it again today and after about 500-600 miles the car has used up another quart of oil. So obviously it wasn't the PCV system, I think it is the guides since the car doesn't puff smoke when it idles, if this is the case then NBD cause I have new TFS heads waiting to go on. However, if the short block is questionable in the slightest then I will get a new engine built for it first. What say you SN patrons?
Thanks
Thanks
