There aren't many things to like about a 4.6 ( especially a 2v 4.6)
Or you put a screw blower on the 4.6 and have 450 lb/ft without the weight penalty and gas consumption issues. Although the FE is a bad ass looking engine and if your going for wow factor, that is the way to go.
I say go with a squirrel motor in a v-shaped configuration. Light weight, eco-friendly, and great MPGs. I'm thinking V-12. Try to stick with similarly sized squirrels. They're easier to synchronize.
All that engine swap stuff is pure speculation for me now. I haven't even got the new combo running yet, so I've got to get that behind me before I even think about what it is I really don't like about the 2v that makes me NOT like it enough to completely start over.
In reality, I like the engine for two of the reasons I listed above as negatives. I like that it looks (and is) externally massive, and I like that there are cams in the heads as opposed to one in the block. Once you get past the unorthodox cam installation procedure, there really isn't anything intimidating about that process either. I like that it's called a SOHC, as it reckons back to the original 615 HP, version that had a 6' long timing chain. And I agree w/ you, making that engine make BB power and torque would be as simple as forcing it to breathe air above 14.7 PSI.
I have always been intrigued by the Teksid alum block. If I could find a place for the alternator (like maybe the rearend) I'd keep it a 2v and build a Teksid base. I'd put a Weiand 174 blower on a custom made manifold, and let my carb hang through the hood w/ some MadMike designed Bug catcher/air grabbing lookin' thing staring at you in your rear view mirror as I come up from behind.:stig:
OK Mr. smarty pants, How do you propose I connect 6 pairs of squirrel cage twins to my current drive train? and what would I use as an accelerator linkage to get the squirrels to run faster?
Well let's see... first you'll need to fab up a custom linkage to combine the power of all 6 squirrels into a common output shaft. The linkage will have to be able to free wheel when not providing torque. This is just in case you happen to blow a squirrel... you'll still be down a squirrel but it won't bog the other squirrels down.
The throttle linkage is easy. All you need is a small trap door and tiny muffin fan. The door will raise as push the gas pedal down, revealing more of the squirrel food that is contained within. The tiny fans are variable speed and help to waft the smell of squirrel food to the squirrels (the fans are not required but it's similar to a CAI).
Finally... when you need jump into traffic or find yourself facing that ass-wipe at the stop light with pants hanging down around his ankles and his hat on backwards, and little switch activated cattle prod affixed to the rear of their tiny cages. That honduh won't know what hit it. O_o
I liked my 2V 4.6L just fine. Ran smooth as glass and with the blower on there it made more than enough power to put many an OHV 5.0L on the trailer. Got 26mpg and super clean emmisions too.
Nothing wrong with that engine. Never puked a head gasket, wore out a water pump, had a leaking intake gasket, or split a block like many of the 5.0L guys regularily do ehen the start putting the power to their engine.
Each engine has it's high and low points fellas. :)
Finally... when you need jump into traffic or find yourself facing that ass-wipe at the stop light with pants hanging down around his ankles and his hat on backwards, and little switch activated cattle prod affixed to the rear of their tiny cages. That honduh won't know what hit it. o_O
Oh sure, as long as all of that fab stuff is left to me then "potentially speaking" it's all do able ( on paper).
While it sounds really cool, if I cant buy a kit like that, I'm not even gonna consider it. The last time I tried to go around conventional wisdom, I ended up w/ a dented sink, a 7.5" hole melted in the middle of a solid sheet vinyl sterilized floor, and had to rush one of my friends to the ER to have 27 chunklets of hyper-frozen, fragmented differential cast iron removed from his body.:nonono:
While it sounds really cool, if I cant buy a kit like that, I'm not even gonna consider it. The last time I tried to go around convetional wisdom, I ended up w/ a dented sink, a 7.5" hole melted in the middle of a solid sheet vinyl sterilized floor, and had to rush one of my friends to the ER to have 27 chunklets of hyper-frozen, fragmented differential cast iron removed from his body.:nonono:
Question about that by the way. Does your friend now cause the alarm to sound when he goes through and airport terminal?
No, but he kinda looks like the Korean guy w/ the diamond face on that James Bond film
( Only w/o the diamonds of course)
(And he's a white guy)
(Nothing against Koreans or anything)
Reactions: Noobz347
I agree Gearbanger 101...our engines are underpowered but they can handle a heck of a lot more than an OHV. And the 2V engines run smoother. Our cranks (even the stock ones) are very hard to break as are the 86 lb aluminum blocks. However this I attribute to the design of the block. Our blocks are 4 bolt mains with 2 cross bolts vs the 2 bolt main OHV engines. And our blocks are solid all the way through vs the OHV blocks with the cam going through the middle...that compromises the block's integrity. But I gotta say, the power of a 351W is nothing short of exhilarating and insanely addictive!!
Still tho I don't think Ford went to any lengths to make the 2V engine formidable. I think they slacked figuring they could save costs and just let the aftermarket handle everything else. That's probably why they have boost friendly compression. And further I think they wanted the cars to be a bit on the comfy side...gotta admit the New Edge GT's are about as comfy as a V8 Mustang can get. Anyway, I agree with everything that everybody has said about them, but still I like my 03 GT. It's easy to drive, it's moderately quick, the interior is nice, it's easy to get in and out of, it's easy to keep clean, and 9 years later and the car always gets looks and compliments...and I got a 5.4 with stage 2 heads and cams ready to go!!
How fast did that Cougar run at the track? How much money/work did you have in that engine?
I'm sorry, I'd take a squirrel motor over a 4.6, haha.
(No offense Mike, I still think you do great work!)
Hey I'm not offended.
I'm the one that owns the engine that starts a thread about it's potential, percieved , uhhhh,...shortcomings.:shrug:
But it is what it is. If I was building the car to set the world on fire, it'd have a different engine in it. For the purpose it's serving presently, I like it just fine. If the new heads add a feel-able difference to the previous version,.....then all the better.
For the record: The thread was really only about the aircraft hangar Ford put under the intake manifold.:D
Haha, I know, but this is Talk, and in Talk we never stay on subject.
