1988 Check Engine, Gas, Washer Fluid, etc. Lights
RedVert88
I have a question about the lights on the lower right hand side of my cluster bezel. I bought the car in July of 2011, and I always knew that those lights didn't work. However, the yesterday I was replacing the dimmer switch, and while everything was torn apart, I noticed that the entire check engine, gas, washer, etc. unit was not there. It's not that the bulbs were out or something. There is just nothing behind the lenses.
So my question is what does this thing look like? Was that ever a factory delete option, lol?
Also, I have no buzzer/chime like when the lights are on and the door is open. Are these things related?
Thanks!
The part you mentioned is part of the GT option package. There is a small flexible plastic sheet that acts as a circuit board for the wiring and light sockets. It overlays the standard plastic circuit sheet and makes contact with body wiring connector. There is a white plastic holder for the light bulbs that the flexible plastic circuit sheet connects to.
The chime loses its voice over time and will get so faint that you can no longer hear it. I don't have a fix for that at this time.
You can pull the codes in any 86-88 Mustang just like the 89-93's. If has the same code-management system. Only difference is no light on the 86-88 cars.
So if there was a code stored, you would never know it unless you just randomly checked.
So guys with SD setups should routinely code check. I do in on my car every couple months or whenever something doesn't feel right.
Dumping the computer diagnostic codes on 86-95 Mustangs
Revised 26-July-2011. Added need to make sure the clutch is pressed when dumping codes.
Codes may be present even if the check engine light hasn’t come on, so be sure to check for them.
Here's the way to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
Post the codes you get and I will post 86-93 model 5.0 Mustang specific code definitions and fixes. I do not have a complete listing for 94-95 model 5.0 Mustangs at this time.
Be sure to turn off the A/C, and put the transmission in neutral when dumping the codes. On a manual transmission car, be sure to press the clutch to the floor.
Fail to do this and you will generate a code 67 and not be able to dump the Engine Running codes.
attachment.php
attachment.php
What to expect:
You should get a code 11 (two single flashes in succession). This says that the computer's internal workings are OK, and that the wiring to put the computer into diagnostic mode is good. No code 11 and you have some wiring problems. This is crucial: the same wire that provides the ground to dump the codes provides signal ground for the TPS, EGR, ACT and Map/Baro sensors. If it fails, you will have poor performance, economy and driveablity problems
Some codes have different answers if the engine is running from the answers that it has when the engine isn't running. It helps a lot to know if you had the engine running when you ran the test.
Dumping the Engine Running codes: The procedure is the same, you start the engine with the test jumper in place. Be sure the A/C is off, and clutch (if present) is pressed to the floor, and the transmission is in neutral. You'll get an 11, then a 4 and the engine will speed up to do the EGR test. After the engine speed decreases back to idle, it will dump the engine running codes.
Alternate methods:
For those who are intimidated by all the wires & connections, see Actron® for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Wal-Mart.
Or for a nicer scanner see Equus - Digital Ford Code Reader (3145) – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $30.
Those lights never worked in my 89 either. I had the bulbs and such for them, they just never turned on lol. The cluster I have right now is out of an 89 as well and it has the same thing. Ill find out if it works when I get around to my EFI swap..
