I tryed putting a switch on it, i pulled the panel off, ran direct power to the motor it works just fine and as fast as it should, the passenger window will not work from either side, i checked the fuses under the dash, changed the 20 amp breaker, (not sure if does anything). changed the regulater under the hood, which i do not think has anything to do with the windows. is there ANYTHING i can try to make my window work??
