All I did was set my idle via the Professional products instructions. I had to loosen up the CAI tube, each clamp to twist each section some so I could see in the tb to make sure the butterfly was closed. I put everything back together and set the idle per their instructions. After setting the idle and taking for a drive the car drove a little different, different as in not that responsive on lower end or up over 3500. I mean over 3500 yes power comes on better but it still didnt feel like my car does when it has driven its best. I mean after all I have done lately it shouldn't have gotten worse.
It even popped a few times, different times while messing with it over about a 2 hr period. Almost like a pop/backfire. Twice it stalled when slowing down and threw it in neutral to come to a stop. Got it home and checked codes and with KOEO test I got a 113- IAT sensor circuit open or reads -40. Also got a 157 MAF sensor circuit below minimum voltage. I put in another IAT sensor and adjusted the maf though it was already straight up. Checked all the clamps and made sure everything was good and tight, cleared codes took for a drive and same thing. I played with the idle some more over the course of the 2 hrs and set tps each time. When I first messed with the idle today it seemed as if the throtte response was much more responsive with car idled at about 11-1200 so that was the last thing I did tonite was put it back there , reset tps and took for a drive. It felt a little better but when I got back home and checked codes I still got the 113 and 157 with koeo test.
Thoughts
Thoughts
