Progress Thread Project Copper Can
So i am sending my car down this weekend to go get painted the last time. I had to rig my motor to be held in but i didnt wanna put my junk t5 back in so i took the bell housing ans cross member and stuck a 4x4 in the bell housing and lag bolted it to the cross member has anuone ever done this i feel ie macgyver over here ill post pics tomorrow evening of what i did :)
A couple of months ago I was looking at an '85 t-top, missing the trans crossmember, so the guy took a 2x4 and a piece of rope and tied the tail housing on the tranny to the 2x4, with the 2x4 on top of the shifter hole. Your way sounds better than that!!!
Yeah, I think you should be fine, as long as your motor mounts are healthy, if one of them were to separate then you might have a problem, but the way it sounds, I'd say you're good to go.:nice:
Well that was the thing was i just replaced my solids from previous owner to polys ajd the polys had lots of wiggle with the motor by itself wanted to lean back to the back of the tunnel
Back from paint time for re assembly
Yeah buddy im gonna take some more pics tonight but since i went from an lx wing to a gt wing i need a new hole to route the third brake light harness
.. should i start out with a drill bit then go hole saw bit or could i get away with just hole saw bit?
Got some more work done on the wiring the back tail light section is mostly done and i started mocking up the engine harness and im going to try to do a write up on this harness and how to do a tuck for it that i found very simple to do so stay tuned.
Reactions: chgovfk
Oh, I'm definitely a local there. My body may be in NC but my heart is in Maryland. I go there a minimum of 3 times a year and sometimes more. I have friends there that still call me on an almost daily basis. We just got my son-in-law a used Mercury Milan there. And here in NC some of my best friends are also from MD.
got more of the wiring done it was a lot simpler then i thought it was gonna be to get the chassis harness back in and sorry RacEoHolic330 but i didnt use the ron francis kit i reused my factory harness. but anywho i also took some other pics of the engine harness and how i routed it and am planning on mounting it up.
this is where i poked through the fender to do the wire tuck please dont hasle me about the marring marks, my drill bit for the hole saw bit broke and messed me all up.
this is how the harness looks laying around i got it connected now just not mounted if you do it this way there are three plugs you need to extend, both connectors that connect to the windshield motor, and for the coil connector, you can leave the coil in the fender but i dont want to.
what it looks like from the other angle.
this is a pic of the dash area, everything is connected back up and i remoed the air bag circuit and sensors there are three up front and one behind the driver in the b pillar. everything that isnt connected in this picture is either not being connected or the accessory is not there to be connected
this is the dash section of the rjm harness. it will be attched up behind the ac box. it has enough slack to be able to do that.
this is how im planning on mounting my eec power relays and fuses. it is behind the glove box but is not in the way of the glove box opening which is great but the only way that i can think of mounting this is 3M double sided tape, if anyone has some other ideasim open to them but thats my progress so far.
