Had to do a little trimming of the shroud and make a set of custom brackets, but it all bolts up fine. Overflow bottle also needed a custom bracket, but it fits in nearly the stock location.
Yes, mine is a Fox body.
Steve, are you running underdrive pulleys by chance? I had them on mine and found they were unable to keep pace with the demands of my fan (even after the 150A 3G conversion). I could always see the draw on the electrical system when my lights would dim as the fan kicked on and hear it speed up as I brought it up above idle. Even with the smallest alternator pulley possible, it still wouldn't keep up until I switched back to the stock pulleys.
Hi
The reason I asked about fox's is I did research (search function) and thought I had the answer til I realized it was a fox body thing...
Had underdrive for a while..... 10 years ago ?? when I first bought car.... more hp
No I don't have them know.... didn't work too well with the supercharger. Just going to try this,,,, only a few hundred dollars.
Pretty sure it will work. I am a little worried about the amp draw.... but am pretty sure it will be ok. Did some research on 3 core radiators decided it might not be enough and was pretty expensive. The engine is fine around town. It's the miles of stop and go on the Hot Rod tour that got me.... i like my air.
Steve
.. Pulled them off when I went with the supercharger, don't remember why exactly but there was an issue.
Then do some real life testing (driving). I don't drive it every day. So it may be awhile til those results are known.
