can i run a 65mm EGR spacer plate on my stock throttle body? and before give me the run around about doing other mods first, im going to but im going to order the EGR spacer first because money is tight right now.
you could but you wont see anything from it.
save your money for an explorer top end or you can make your own knock off Anderson Power Pipe which will you give you more benefit than an egr spacer.
Not sure what the reason is for purchasing the 65mm spacer but as mentioned above, you will see ZERO gain from it. If it's a freebie or something, just set it aside until you have the throttle body to go with it.
