Fox New Here: Saying Hello With Questions
Here... This is the nipple I need to get to...
Remove the upper intake manifold - 6 bolts, 2 of which are hidden under the 5.0 cover plate. Then you get to pop off the throttle cable, inlet air duct and some other miscellaneous hoses and electric connections to get the upper intake manifold off.
Seriously, it is time for a Chilton's shop manual...Buy one before you break something expensive.
5-0-ford-intake-manifold-exploded-view-gif.531467
Reactions: polaraman
I like to hear success stories and not tales of woe. The manual is a good first step...
I need to update everyone. Chilton manual ordered. Should be in by this weekend.
I was able to swap out that vacuum line under the intake without taking it off. It was a very tight fit but I got my hand up in there. My surging idle is fixed!!! :) Thanks to everyone for their help.
However, I've encountered another issue. I've driven the car all week with no issues until today. I drove it home from work and had to run back out. When I tried to crank, it was flooded. I waited about 10 minutes and tried it again. It ran for about three minutes and flooded again.
What would cause the engine to flood like that? I can smell the gas it's not burning. It's a very strong smell.
Fuel pressure regulator??
Pull vac like off the fuel pressure reg if there is fuel coming out its 100 percent no good
Reactions: jrichker
EFI strategy to clear a flooded engine: Hold the accelerator to the floor and crank the engine. When it starts, quickly let off the throttle.
Fix: follow TOOLOW91's suggestion to check the vacuum line on the fuel pressure regulator.
If you don't find or smell fuel, then dump the codes and look for ECT codes 21, 51 or 61.
Dump the codes: Codes may be present even if the Check Engine Light (CEL) isn't on.
Dumping the computer diagnostic codes on 86-95 Mustangs
Revised 26-July-2011. Added need to make sure the clutch is pressed when dumping codes.
Codes may be present even if the check engine light hasn’t come on, so be sure to check for them.
Here's the way to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
Post the codes you get and I will post 86-93 model 5.0 Mustang specific code definitions and fixes. I do not have a complete listing for 94-95 model 5.0 Mustangs at this time.
Be sure to turn off the A/C, and put the transmission in neutral when dumping the codes. On a manual transmission car, be sure to press the clutch to the floor.
Fail to do this and you will generate a code 67 and not be able to dump the Engine Running codes.
attachment.php
attachment.php
What to expect:
You should get a code 11 (two single flashes in succession). This says that the computer's internal workings are OK, and that the wiring to put the computer into diagnostic mode is good. No code 11 and you have some wiring problems. This is crucial: the same wire that provides the ground to dump the codes provides signal ground for the TPS, EGR, ACT and Map/Baro sensors. If it fails, you will have poor performance, economy and driveablity problems
Some codes have different answers if the engine is running from the answers that it has when the engine isn't running. It helps a lot to know if you had the engine running when you ran the test.
Dumping the Engine Running codes: The procedure is the same, you start the engine with the test jumper in place. Be sure the A/C is off, and clutch (if present) is pressed to the floor, and the transmission is in neutral. You'll get an 11, then a 4 and the engine will speed up to do the EGR test. After the engine speed decreases back to idle, it will dump the engine running codes.
Your 86-88 5.0 won't have a working Check Engine Light, so you'll need a test light.
See AutoZone Part Number: 25886 , $10
Alternate methods:
For those who are intimidated by all the wires & connections, see Actron® for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Wal-Mart.
Or for a nicer scanner see Equus Digital Ford Code Reader (3145) Equus - Digital Ford Code Reader (3145It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $22-$36.
Reactions: TOOLOW91
