mikestang63
SN Certified Technician
That's what I thought about injectors. I will be going with a custom ground cam. And the intake may be switched for a trick flow. That's not definite. But that's a pretty solid combo, and I assumed I would definitely need 24# injectors, and I planned on going with a 255 pump.
If you are going with a custom cam, I would get 30# injectors and at least a 75MM MAF. No sense in maxing out your injectors and it gives you room to grow.
