95BlueStallion My assy trans to myself 15 Year Member Feb 22, 2007 5,126 3,091 214 Cedar Rapids, Iowa Apr 10, 2016 #41 Apr 10, 2016 #41 Sweeeeeet!
Davedacarpainter Chicks can make things hard if they’re inspired... SN Certified Technician Nov 28, 2015 11,833 11,633 203 Discordia Apr 10, 2016 #42 Apr 10, 2016 #42 Do you have any pictures of your finished rear undercarriage? I'm starting my version of a min-tub this week, I just want to see how you did it. Maybe steel some ideas that way.
awilli93coupe Active Member Jan 25, 2016 101 104 38 Apr 10, 2016 #43 Apr 10, 2016 #43 Davedacarpainter said: Well hell! There you are! Man, that looks so sweet. I'm getting almost a duplicate of your set up for my car. I'm going to get my wheels powder coated to match my GT stripe is about the only difference. Hot, hot, hot brother. Good job! Click to expand... Thanks dude Sent from my iPhone using Tapatalk
awilli93coupe Active Member Jan 25, 2016 101 104 38 Apr 10, 2016 #44 Apr 10, 2016 #44 Davedacarpainter said: Do you have any pictures of your finished rear undercarriage? I'm starting my version of a min-tub this week, I just want to see how you did it. Maybe steel some ideas that way. Click to expand... Sent from my iPhone using Tapatalk Reactions: skyline247, RaggedGT and Davedacarpainter
Davedacarpainter Chicks can make things hard if they’re inspired... SN Certified Technician Nov 28, 2015 11,833 11,633 203 Discordia Apr 10, 2016 #45 Apr 10, 2016 #45 awilli93coupe said: Sent from my iPhone using Tapatalk Click to expand... I've decided after @84Ttop 's recommendation to go with the single adjustable QA1's myself. Where are they mounted on the top side? I can't quite make out what you did, it looks like on the outside of the frame?
TOOLOW91 If you're the village idiot what's that make me? 20+ Year Stangneter Nov 29, 1999 8,489 8,718 234 S.I.NY Apr 10, 2016 #46 Apr 10, 2016 #46 awilli93coupe said: Sorry I have no had time to post anything I've been working day in and day out on this but here is my finished mini tubbed fox body Sent from my iPhone using Tapatalk Click to expand... I'm over here drooling on the floor . Sick !!!!! Reactions: Davedacarpainter
awilli93coupe Active Member Jan 25, 2016 101 104 38 Apr 10, 2016 #47 Apr 10, 2016 #47 Davedacarpainter said: I've decided after @84Ttop 's recommendation to go with the single adjustable QA1's myself. Where are they mounted on the top side? I can't quite make out what you did, it looks like on the outside of the frame? Click to expand... I will have to put a picture up of it! The bolt goes through the frame and they're mounted inside actually between the frame and bar Sent from my iPhone using Tapatalk Reactions: Davedacarpainter
awilli93coupe Active Member Jan 25, 2016 101 104 38 Apr 10, 2016 #48 Apr 10, 2016 #48 TOOLOW91 said: I'm over here drooling on the floor . Sick !!!!! Click to expand... Haha thanks man Sent from my iPhone using Tapatalk
awilli93coupe Active Member Jan 25, 2016 101 104 38 Apr 10, 2016 #49 Apr 10, 2016 #49 Davedacarpainter said: I've decided after @84Ttop 's recommendation to go with the single adjustable QA1's myself. Where are they mounted on the top side? I can't quite make out what you did, it looks like on the outside of the frame? Click to expand... Oh and by the way! I am still running a stock tank under there [emoji41] Sent from my iPhone using Tapatalk Reactions: skyline247, RaggedGT and Davedacarpainter
Davedacarpainter Chicks can make things hard if they’re inspired... SN Certified Technician Nov 28, 2015 11,833 11,633 203 Discordia Apr 10, 2016 #50 Apr 10, 2016 #50 awilli93coupe said: I will have to put a picture up of it! The bolt goes through the frame and they're mounted inside actually between the frame and bar Sent from my iPhone using Tapatalk Click to expand... Now there's an idea I hadn't even imagined. Yeah, would love to see a picture of it.
D Dakotagough New Member Dec 23, 2018 1 0 1 Midale Saskatchewan Canada Dec 27, 2018 #51 Dec 27, 2018 #51 Hey guys! I know this is an older thread but I’m curious awilli93coupe. What did you end up taking off the rear housing on each side? Also did you just use the offset lower control arms ? Thanks !
