You will need tons of different parts so buying them individually you will have a small fortune in it. So the best thing to do is find a donor car with everything you will need.
YOU WILL NEED
Motor mounts
Transmission crossmember if you are changing from auto to manual.
Rear end- optional, some say you can beat on the 7.5 rear for a while.
Driveshaft
Exhaust
Wiring harness
ECU computer- under passenger side dash
Gauge cluster
Fuel pump
Brake hydro booster
Radiator and fan
Rack and pinion
I may be forgetting some things. I will keep updating. If anyone has any specific questions shoot me a message.
about painting. I'm about 2 weeks into this swap. Need to get the brake system hooked up so I can put my pedal assembly in and then I can get the new dash put in as well as the rest of the new interior. Looking forward to cruisin this to ocean city cruise week in Maryland next month hopefully.
