88 Gt Wheels And Tire Questions
Rjaaaaaa
Well-Known Member
Jul 11, 2016
217
159
63
So I have this 88 GT with 17 X 9 cobra wheels, stock front end with swapped out rear end. Not sure what it is in the rear, previous owner swapped out the rear for a disc brake 4 lug rear?? The wheels are very close to the quad shocks but don't rub, front end is another story, the wheels rub the frame when wheel is turned sharp. It looks to me that the offset on the wheels could be changed and this would correct the rubbing ?? These wheels have the spokes located out along the front edge of the rim and the rim is fully behind the spokes, I think if the spokes were set back a couple of inches the rim could stay at 9" or maybe 10" and not rub. The front tire are just peeking out of the fender wells, the rear is still tucked in. Plenty of tire room both ends.
What's out there that will let me be able to turn without rubbing and maybe get some wider tires in the rear.
Yup. That is normal for the backspacing. I will see if I can dig up a part number for these little plastic clips that go onto the power steering rack under the boot. Limits the rack travel so they don't rub.
Fwiw. I run 245/45r17 up front and 275/40r17
Same tire on mine. I have a slight tire rub in front at full lock and the rear tire will if I have people sitting in backseat with big road dips,bumps,etc. But I'm also pretty low in front with the coilovers.
Rubbing on the "frame", or lower control arm? I had this issue with my 17x9's as well, and simply massage at the edge of the lower control arm with a BFG. No more rub.
And your four lug disc brake rear end is likely out of a Thunderbird Turbo Coupe.
Try Steering rack spacer washer
The part number is N804842-S washer. They come in a package of 4.
Reactions: FoxMustangLvr
hey guys thanks for the info, I would like to run 10.5 cheater slicks and I think there is plenty of room with a wheel with the right offset. Any suggestions? offset #, I'd like to keep the 17" wheel due to the 4:10 gears.
By moving the hub inward through offset the rim will be moved outboard allowing more inboard room.
All depends on if they used fox lengthy axles with the 4 lug disks or used the 93 cobra lengyt axles which stick out 0.75" more
Sent from my big ass iPhone 6 using Tapatalk
Then sounds like it's fox length disk brakes. Easy way to confirm is to poke your head around the backside of the brake setup and look at the axle bracket. If it has an offset like this, it's probably a north race cars bracket.
Vs a factory bracket
If you run a 17" wheel tire choices are slightly more limited for a "cheater slick". I assume you're talking about a dot legal bias ply tire from brands like Mickey Thompson/Hoosier/M&H etc. There are a few options there. Also you can look into a drag radial version. I prefer the bias ply with a manual trans. Just a FYI the bias plys aren't as stable on the big end of the track and are like ice skates on the street if there is any moisture on the road. They also wear fast. Look for a 275/40-17 sized tire(or equivalent) just check out advertised section width. Most 10" wide tires fit. You may have to "massage" the wheel well with a hammer and remove quad shocks(which aren't necessary if running a good set of control arms).
Thanks a lot for the info, but you hit on my question in your last comment about back spacing, is back spacing and offset the same thing? If the placement of offset or back spacing is changed I believe the tire will fit without any need for fender work or removal of quad shock. You guys have been working with these tires a whole lot longer than me. I just don't want to buy new tires for these 17's if I have to change sizes to get a wider tire rim combo.
here is a diagram and an article of what I am getting at.
As explained you can see that most wheel(including my 17") are positive offset but if you go to a zero offset you can see how it moves the tire out towards the wheel well opening.
well it looks like I answered my own question but I hope this info is helpful to all. now when I go rim shopping I'll know what to ask for.
The MGA With An Attitude
WHEEL OFFSET Clarified - WL-200
If you are reading this page you may already be concerned about a difference of opinion about what is called "Positive" or "Negative" wheel offset. I have revised a couple of web pages already for clarification (mostly trying to remove any reference to positive or negative), but the argument persists. I believe the confusion stems from a change of view over the years where some of us are still stuck in the 50's and 60's while the world has moved on to something else. So I will take this opportunity to ramble a bit about history and viewpoint. First a diagram of what's causing the controversy.
My own experience starts in the 1950's when most cars in North America were rear wheel drive and BIG and had wheels with no offset. Having the centerline of the rim coincide with the bolt-on surface makes for the least stress on a wheel when a car is traveling in a straight line hitting bumps and pot holes, which is the way most cars do most of their travel mileage. In the total life of a vehicle, the time a car spends with the front wheels pointed anywhere other than straight ahead is a very small part of the vehicle life (maybe less than 1%).
In those days it was common when "hot rodding" cars to install wheels with a substantial offset to provide a wider wheel base for better stability, or to allow installation of wide wheels and tires without interfering with inboard chassis or suspension parts. These were simply called "offset" wheels with no reference to positive or negative. Wire wheels in particular have a wide central splined hub, so the flat inboard hub surface (next to the brake drum) is substantially inboard from the rim centerline, so much so that the rear axle is built shorter to maintain the desired track width. It was very unusual to find any wheels offset in the other direction (except a few of those "little import cars").
With the advent of front wheel drive cars and independent rear suspension there was a problem with minimal length of the lateral drive shafts. This brought the need to introduce dished wheels with the center hub set substantially outboard. Since the wheel rim and tire were to be set inboard from the mounting surface it would be called "inset", which was commonly explained as "negative offset". The world would be less confusing if we still used the terms "offset" and "inset" with no reference to positive or negative.
Let the automotive world evolve another 40 or 50 years and we have more front drive cars than rear drive cars. These days it is more common to see small cars and cars with front drive and independent rear suspension or all-wheel drive. Now it is less common to see zero offset, and generally uncommon to see wheels going the other direction. As such, people wishing to ignore the reference to positive or negative will usually be comparing offset of one dished wheel to another dished wheel, and going the other direction is rare and uncommon, so they would call that "negative". Now to justify the new view of which direction is positive or negative they switch to referring to the direction of hub offset rather than the rim. Positive offset is still outboard, but now they are referring to the hub offset rather than the rim offset (very convenient).
Not confused enough yet? Another way of measuring wheels is to refer to "backset". Backset is the distance from the inboard rim edge to the bolt-on mounting surface of the hub. Lay a straight edge across the inner rim and measure to the mounting surface, and you get backset as a direct measurement. Measuring across the full width of the rim gives you "rim width". Measuring in between the tire bead mount surfaces gives a consistent measurement of what is ALWAYS referred to as "wheel width". You can easily convert measured overall width and backset measurements to offset dimension by the formula B-(W/2). Rim edge design makes no difference, as W/2 is always the centerline of the rim regardless. The result may be positive or negative depending on wheel shape.
Once you understand how all this works there is no confusion at all about offset, only whether people refer to it as positive or negative. This is why anyone referring to these dimensions as positive or negative will always have to explain which direction they are calling positive. This is one issue that may never be consolidated to one standard in the "political" world. However, by now most wheel suppliers have settled fairly consistently on the newer point of view and refer to outset hubs and inset rims as "Positive Offset". So here is the new diagram with the modern terminology.
Reactions: LiquidStangs
