4k buy the time you get settled in. This includes blower kit, injectors, MAF, A/F and boost gauges. Then sprinkle in other stuff along the way.
Many of us have done this and then had head gasket problems putting our cars out of service until we spend more time and money. So depending on the situation of your engine, you may want to first pull the heads and redo head gaskets. This includes milling heads, decking block and going with upgraded gaskets. I've blown the Felpro 9333's and I'm done with them. Now my block is at machine shop getting prepped. This time I'm using Cometic gaskets.
well, my engine is as follows and only has about 2300 ,miles on it since rebuild.
stock bottom end with new rings,bearings,oil pump,etc
was built on the tight side with king bearings, but for the life of me, cant remember what i got my clearences at on the rods and mains..i just know it was in spec but on the tighter side. the block had been decked so much by previouse owner, the pistons just did come out of the deck. took a machinist straight edge to it and it looked straight, so i left it alone.lol
*Anderson n41 cam, stock lifters with unknown miles. but hey, they work.lol
*new pushrods after discovering the stock ones had 1 bent
*crappy proform 1.6 roller rockers that never seem to be shimmed right.....maybe i do need new lifters??...hmmm
* upgraded valve springs with 153lb/seat preassure on intake and 149lb/seat pressure in the exhaust. the set just ended up having that difference when i tested them.
* f3ze gt40's that i milled .015" off for 61cc cambers to end up with right at 9.7:1 compression.some light bowl work and cleanup/porting on the intake with a good bit of work on the exhaust side new seats,reused stock valves
*24lb injectors that were used(regretting that)
*china edlebrock clone intake.
*65mm TB
* c&l elbow and 76mm MAF housing and 24lb sampling tube and filter stuck on the end.
*long tube headers,offroad H-pipe and 40 flows 2.5" through out
rest of the car is
*ram HDX clutch rated for 400hp(? i think)
*new astro budget t5
*stock drive shaft
*3.73's and a posi thats starting to show its age.
* subframe connectors that i welded in.
car weights in a 3020lbs with a half tank of 112 and me in it. its a 91 gt.
i havent yet had it to the track. bench racing says with all things right, i would be around the low 12's very high 11's.
dynoed at 308WHP with no tune.
with all that in mind, i want to put a walboro 255 in the tank. previous owner said it had a 155 but he lied about everything else,so i dont trust that. what do yall think would be my best course of action? i cant remember the part number on the head gaskets but they were the blue felpros with the steel ring.
