Where To Buy 42lb Injectors
If you were going to digitally tune, why would you also buy a calibrated meter?
Car is going to be controlled by a MSPNP box I built, so mass air is going away. I talked to the tuner yesterday and I'm hoping to get it to him in March some time. Going to order those 47lb injectors, get the rest of the kit installed and I should be good to go.
He's really pushing me to put an intercooler on it. I've told him there are thousands of these kits running 8-10lbs of boost that aren't intercooled. What's your guys thoughts?
Coming from a guy on straight pump gas running 13psi through an s trim on a 360 inch motor. It can be done. With that said an air to air intercooler would free up some good power i believe taking the heat out of the charge air.
If I were to have him tune it without an intercooler and then add one later, would it need to go back to re-tune? Or is it just a matter of adjusting tables in my MS that wouldn't be too big of a deal?
Shouldn't be big deal at all . You will prob see a little less pressure with the intercooler that's all . But the blower will definitely be more efficient
Reactions: Sparky714
@Sparky714
Anything else you have any questions about feel free to tag or pm me . I play with the centri blower stuff quite often . If I can't answer it or resident blower guru my buddy @84Ttop can
