Usually you aren't at the tuner when you fire it up the first time
Yep, that's a good reason.
Car is going to be controlled by a MSPNP box I built, so mass air is going away. I talked to the tuner yesterday and I'm hoping to get it to him in March some time. Going to order those 47lb injectors, get the rest of the kit installed and I should be good to go.If you were going to digitally tune, why would you also buy a calibrated meter?
Coming from a guy on straight pump gas running 13psi through an s trim on a 360 inch motor. It can be done. With that said an air to air intercooler would free up some good power i believe taking the heat out of the charge air.Car is going to be controlled by a MSPNP box I built, so mass air is going away. I talked to the tuner yesterday and I'm hoping to get it to him in March some time. Going to order those 47lb injectors, get the rest of the kit installed and I should be good to go.
He's really pushing me to put an intercooler on it. I've told him there are thousands of these kits running 8-10lbs of boost that aren't intercooled. What's your guys thoughts?
If I were to have him tune it without an intercooler and then add one later, would it need to go back to re-tune? Or is it just a matter of adjusting tables in my MS that wouldn't be too big of a deal?Coming from a guy on straight pump gas running 13psi through an s trim on a 360 inch motor. It can be done. With that said an air to air intercooler would free up some good power i believe taking the heat out of the charge air.
Shouldn't be big deal at all . You will prob see a little less pressure with the intercooler that's all . But the blower will definitely be more efficient
Thanks! Still undecided about the intercooler. But we still have a few months of winter left here in North Dakota, so no big rush yet.@Sparky714
Anything else you have any questions about feel free to tag or pm me . I play with the centri blower stuff quite often . If I can't answer it or resident blower guru my buddy @84Ttop can
guru?@Sparky714
If you're the village idiot what does that make me ?guru?you mean village idiot?
I see someone struck on this one . @Noobz347 ? LmaoIf you're the village idiot what does that make me ?![]()
I like to keep the guru thing low keytook me a minute
