The Motor Is Out!
HotRodBlack
31
15
28
Engine was making noise, it was driving me nuts pretending it was ok.
Pulled it out, wanna tear it apart and see what it is.
Common problems with high mileage 302 ho motors? Aaaaand go.
Also wish me luck!
They're worn out?:shrug:
Most I can offer without a better description of the sounds it was making.
You say you already have it pulled? What're your plans?
If you already have it pulled, you might as well......tear it down, put in new bearings,seals, timing gear set, hi volume oil pump, better flowing heads, custom cam, stroker forged crank(Callie's:nice:), forged rods and pistons, anything that says ARP, dart block, turbo, jack stands,supercharger, etc....etc....
Give us a couple details or do the above list.:D
I'm thinking you could have discovered what the problem was without pulling it simply by checking codes or asking us what we thought. I think you pulled the engine because you want to build it back yourself. That's good though. It's fun and rewarding to do an engine tear down and rebuild and have it run again because you did the work.
Seriously, tell us about the problems first. Our engines will have all sorts of problems depending on how they were treated.
I actually had a post before with two videos of the noise... very little input from anyone...
Perhaps I was not direct enough in my questions. Idk.
The plans for the engine are just to get it repaired and put back in the car. I am not gonna go nuts with this engine as I don't have the money for a stronger transmission, so I'm not gonna push over 300 hp. Im gonna tear it down and measure everything and make sure it's viable. You know, check cylinder walls for scoring or loss of cross hatch pattern. I'll check all my bearing clearances and determine what it's gonna need. As of right now I'm 85 percent certain I will need main bearings, as there is too much crankshaft play, so those thrust bearings are poop. Tearing it down will tell me if the crank is viable or not, and if I need pistons and whatnot.
Currently this engine has an edlebrock intake, a set of bbl headers and h pipe hooked up to some warlock mufflers with dumps. Crane rocker arms (i can see through the oil fill) and a mild cam. I do not know what manufacturer the cam is. It's got a Bbk cold air kit on a stock t body and stock injectors. If anything, gt40 heads and a 65 mm tb plus 25lb injectors and mass air meter to match... but that's as far as this needs to go for now. Just a hot street set up.
I've probably even read your previous posts and have misplace them in my brain. Sorry dude, not meaning to be disrespectful, my life is full at the moment.
I think I remember a post or two by you. It would help to connect that memory if you might post a link or two.
Honestly, if I remember correctly, it could be something as simple as a loose valve train. Valve seals wear out, rockers need adjusting, etc...
Reactions: Davedacarpainter
You will soon be dreaming of mo powa
It starts with a simple 'fresh'n up' then 'well maybe I'll up grade this' and 'a better that' next thing you know you'll be sleeping in the garage, eating baloney sandwiches and drinking PBR so you can buy that turbo because those black marks in front of your house just aren't long enought.
:burnout:
:burnout:
I'm sure you're right... but my budget will not allow it right now
Reactions: General karthief
:burnout:
I like me some PBR regardless of finances :cheers:
Wow, I just realized we have the popcorn emoji back, @Noobz347 thanks bro!
:pop::pop::pop::pop::pop::pop::pop::pop::pop::pop::pop::pop::pop::pop::pop::pop::pop:
UPDATE
Tear down is complete! It's not good...
Cylinder 1 intake lifter is compromised... the roller is a semi circle. Cam lobes are worn pretty good, lots of pitting. Some of the lobes are squared off.
Every single rod bearing is worn down to the copper. Main bearings are just as bad. Cylinder 5 is physically twisted around and was knocking.
Crankshaft is worn .015 under min spec on the rear two journals... significant scoring present as well, I can catch a fingernail in the grooves.
Cylinder number 8 piston is compromised, it's stuck on its wrist pin.
Didn't pull the cam to inspect the bearings, odds are not in their favor.
Cylinder bores are within spec, no significant loss of cross hatch pattern just worn over time.
The block is salvageable, heads are salvageable, that's about it.
Poor thing was just worn out. Rode hard and put away wet all its life.
