They're worn out?
Most I can offer without a better description of the sounds it was making.
You say you already have it pulled? What're your plans?
If you already have it pulled, you might as well......tear it down, put in new bearings,seals, timing gear set, hi volume oil pump, better flowing heads, custom cam, stroker forged crank(Callie's
), forged rods and pistons, anything that says ARP, dart block, turbo, jack stands,supercharger, etc....etc....
Give us a couple details or do the above list.
I'm thinking you could have discovered what the problem was without pulling it simply by checking codes or asking us what we thought. I think you pulled the engine because you want to build it back yourself. That's good though. It's fun and rewarding to do an engine tear down and rebuild and have it run again because you did the work.
Seriously, tell us about the problems first. Our engines will have all sorts of problems depending on how they were treated.
