Okay I finally got to look this problem over. I was finishing up other stuff first.
Also I forgot to note. The front end was hit on this car and repaired before I bought it. That probably caused and air bag issue....but anyhow.
I checked the fuses, they are all fine. Theres a LOT of 30 amp fuses in my box??? Ugh!!
Anyhow, I used a stethescope and found the beeping blue box, the blue one behind the console.
I unplugged the two plugs in it, and the CEL stayed on when I started the car.
I scanned it, and it came up throttle positioning sensor. Quite odd! I don't have a CEL normally, and didn't have that code before. I cleared it with my scanner since this car does not have that issue normally.
Anyhow, I plugged the two plugs back in, and took the car for a ride. Light stayed out as usual, and the beeping is still there.
I thought unplugging the blue box would help the beeping stop.. Don't know why unplugging it caused a TPS code. Very odd. But the light is out now, and never came back on.
Here's a photo of the blue box thats beeping. I was hoping unplugging the two plugs would stop it from beeping. It may have, but the CEL comes on with a TPS code.
