Engine Maf Sensor Help Please!
You may be able to buy a maf sensor from the parts store, I have read a couple threads in other places that had the wrong sensor in a 95 maf. Make sure it has the 2 and not the 5, I don't know if the maf you got was a replacement unit or what. Maybe you should compare that maf with another like from a crown vic or town car 92-94 4.6
Reactions: Cabrera93stang
I try that tomorrow.
Thanks
I tried this also with the v6 maf and when I switched it I noticed at the track I was having a hard time getting the same mph that i usually topped at. I was 1-2 mph slower if I remeber right and I thought to change the maf back to the original one and then it went back to my normal mph... Could of been a coincidence but I just kept the original one on. I'll just get a bigger aftermarket one if I get bigger injectors one day.
So I finally found the right part # in going to put it on the housing that I already have from the 94 mustang and I hope everything works fine ..
Fingers cross..
Fingers cross..
uh you don't swap sensor from different housings. The sensors are calibrated for the housing. It may or may not impact the A/F ratio.
Not understanding why you don't just install the entire MAF housing and sensor as a unit.
He has the right sensor for the housing he has.
The sensor shown, and the housing shown will work together.
