- Jun 18, 2017
- 21
- 1
- 13
I try that tomorrow.You may be able to buy a maf sensor from the parts store, I have read a couple threads in other places that had the wrong sensor in a 95 maf. Make sure it has the 2 and not the 5, I don't know if the maf you got was a replacement unit or what. Maybe you should compare that maf with another like from a crown vic or town car 92-94 4.6
So I finally found the right part # in going to put it on the housing that I already have from the 94 mustang and I hope everything works fine ..![]()
Fingers cross..
uh you don't swap sensor from different housings. The sensors are calibrated for the housing. It may or may not impact the A/F ratio.
Not understanding why you don't just install the entire MAF housing and sensor as a unit.
Looks like it's sold. Did you by it? It should work.
He has the right sensor for the housing he has.uh you don't swap sensor from different housings. The sensors are calibrated for the housing. It may or may not impact the A/F ratio.
The sensor shown, and the housing shown will work together.
