- Nov 13, 2016
- 194
- 56
- 48
Okay so I was letting the car run today for just a minute when I got out, and when I came back to the car I heard a light tapping sound and at first I thought lifters but when I got in and pressed the clutch it went away?? Only when the clutch is out and in neutral no noise when it's pressed or while driving idk what this could be
Did you do the Adjustable Quadrant and new factory cable so you can adjust it?
Input shaft bearing? I would think you'd hear it under load as well though.
If you Google it you will see what is involved in the process, but usually out the top is easier for the backyard mechanic.
but i have just never pulled a mod motor. I've decided that out the bottom would be best for me since i have a lift it should be pretty simple
