If I can find another 65mm throttle body I may do it. Would be different and I like that, but they must match. I would need an explorer throttle body so they are the same.are you going to do the y and duel t bodys like we talked about?
Option 3. Build a wild manifold for 2 65mm TB.
Pro: will look crazy, TB are cheap and easy to find at jy.
Con: must build a manifold and linkage.
One tps signal needed, and SD. The only thing that would become problematic would be tuning the accel enrichment. I already have a linkage made up from the m90 setup I would just have to shorten it. (Lokar cable)...and figure out how you're going to split the TPS signals and whether these will run through a single or dual MAFs (or SD?).
This option just sounds like a pain in the balls.
can you try just flipping your current one upside down? if that works, a fox-style 90mm will bolt right one. theres also kits to remote mount the iac or convert to a gm style if that also gets in the way.Come one come all to the give me your opinion box. Today we have multiple options in the supercharger inlet line up.
Option 2. Build a manifold for a single large Ford TB.
Pro: works with current linkage
Con: must fab a new manifold and very costly.
I tried turning the TB all kinds of different ways, no matter what I did the clearance just wasn't there. now a remote mount iac may allow it to work with some creative linkage reworking. The elbow is what is close to the hood, I can flex the hood and touch the elbow.... no buenocan you try just flipping your current one upside down? if that works, a fox-style 90mm will bolt right one. theres also kits to remote mount the iac or convert to a gm style if that also gets in the way.
Only 1 left in stock. Order soon!![]()
you may have something thereThe easy way or kiss sounds a lot like something "other" people would do. Since im not everyone else I prefer the non bellybutton way.
BEHOLD!
Probably if it flows at least 1k cfm.....Will a truck dual throttle body work?
