Cooling Fan Options
Stock alt is ok with stock clutch fan, stock stereo, stock pullies.
Just make sure the plug with the three wires is in good shape, the earlier years, 87-88-89's, had some issues with the plug burning up so check it for burnt, discolored wire connections.
A 3g upgrade doesn't hurt.
If you upgrade the fans to electric you need to do the alternator upgrade. Its fine for a stock set up...but check the wires per karthief. I used a Taurus alternator and re- clocked it. It fit the stock bracket with very little modification. There are two different sized alternator bodies. The pulley is bigger than the stock fox pulley....so I pulled one off a 90s escort.
The alternator in my car now is bigger and only fits because of the aftermarket alternator bracket. It was for a fully loaded 96 Taurus.
The one for a fox is from a 94 3.8 Taurus. Its a fairly easy swap. Run a new 2 ga power wire to a 150amp fuse and holder to the positive terminal or starter solenoid, run a 2 ga. battery wire from the block to the negative battery post, 2 ga. to the body from battery ground. The small wire D connector is the same....just cut the white/black stripe wire ( about 3 to 4 inches ) from the D connector, put a wire spade on it and plug it in the 3g alternator. The wire goes from the D connector in the alternator back into the alternator.
The two black/ orange stripe power wires for the old alt. can be completely removed.
Reactions: General karthief
I’m stubborn and I don’t even need to admit it because you all know. You’ve proven me wrong before and maybe you will again. But I’ll be rogue again.
I’m going with the flex fan for now. It weighs 2.5 lbs less than the stock clutch fan (including spacer and hardware) and it’s also a little quieter. Moves a ton of air at idle and the blades flatten out considerably by 3k rpm.
Not into an alternator upgrade that would be needed for the electric fan setup.
Haven’t test driven with flex fan due to rainy day but I’ll keep you posted.
@John Dirks Jr
I've seen flex fans make a helluva lot of noise. Seen partly-stuck clutches drive fans loud as airplane propellers, too. Have you thought about a smaller than stock plastic job with a clutch? They make them in inch-increments. imp
john, it's hard to beat the stock clucch fan. unless it is not cooling I would leave it be.
if you want a E fan,I would go with the contour dual fan and a FAL 33054 controller
The fan fits the radiator perfect and pulls well over 3300 cfm
My sentiments exactly. If it's making noise (and the bearing is not loose), that means its working correctly. I advise leave it alone/ I have switched my 69 to electric.
Reactions: imp
