4 Speed Manual Transmission For 302 Motor
This should give you the torque specs you're looking for.
http://boxwrench.net/specs/ford_289_302-5.0.htm
As far as gaskets, if you can't find them you could always make your own. I honestly don't know if they make them....
thanks.When I bought this car motor wasn't in it parts every where i've decided to put the manifolds on for now,but I don't know the specs for the bolts,couldn't fine old original ones in the pile that came with the car.it is a 77-cobra 302 motor. I hope you or some else can help. Thanks
thanks.here is better pics,started putting the new clutch and pressure plate on. Had flywheel resurfaced
Reactions: LILCBRA
