Those first cuts had to be a little nerve racking I would guess.
so how bad of a job is it?
looks great man! my only issue doing it would be putting motor plate tabs on the tubes vs the square frame rail. i dont have access to the CNC plasma anymore so cutting tabs is a lot harder than it would have been before
im sure you would have to modify what they make or have them do it. but the frame rails on the X car are stock till the motor plate per the rules. then its all tube after that.I wonder... For someone like myself who'd like to keep the sway bar - Can I leave the frame rails a little long and then weld the tube frame on past that, or does it defeat the purpose entirely?
IIRC blake at 417 claims like 65lbsAny idea what the weight savings is on this swap? Roughly.
The stock nose doesn't weigh 65 lbs I think that number is pretty loaded because they are adding the fact that you now have to relocate the battery to the trunk of the car which that alone is 15-20 lbs. I'd say what I chopped off was about 30-35 lbs and the tubular 417 is 14 lbs
