I get it. Your injector rail governs the room you have.
Man you've got a lot more room for big ports with a short radius that good.
Nice.
Having two rails will surely mess show goers up.
Everything else before your effort has been Crash Avoidance Management 101...it was about avoiding restrictions, and not doing it right because of that.
Well, not wrong, but kind off less bold than what you are doing.
Jacks second X flow conversion certainly followed the crimped throttle body spacing, and yours doesn't have that restriction.
Jacks first X flow showed that you didn't have to deviate.
Your ideas allow a heck of a lot more space for proper intake flow.
I didn't suggest the Chrysler Hemi 265 size port, but since everything your doing is so amped up, I guess Tony Andersons "Ando76" Ute head with 1.693 diameter ports with 2-1/4 sq inches of intake port is possible if you wanna stand up for another six hours at a later stage. So another 68 thou up on your 1.625" diameter will work fine.
212 cfm at 25" H20 with a rise of 550 thou was an easy reach with no other major internal porting work.
He made and inital 334 rwhp at 5900 rpm on Methanol 4-bbl carbed with his C4 auto and solid lifter, non roller Chevy OffRoad and Marine 600 thou, 276/274 at lash and 243/242 at 50 thou cam. Its ground off a GM master, on 110 center. In excess of about 460 engine horsepower. Before he blew up the pistons from a richen out, it logged 340 hp at the bags at 5900 rpm. The Pickup is gone, an victum of sooo much work at the burnout pad in front of fans.
View: https://youtu.be/wBCr4Qzfxf8
Same HF early head as yours
You've got much better induction, a more suitable cam, and the whole pacakge will work nice.
My neigbour used an in line Hemi for his Jet Sprint Hamilton Jet boat....all good 4 liter sixes with a nice cam and Independent Runner intakes sound just as good, the Snap Crackle and Pop of the engine isn't just the Methanol......And the fluid slur of a big inch mutha skimming metal over the Earth.
Enjoy your labor.
Nice.
Enjoy your labor.
