Color me happy.............(What color DO you paint yourself when you're pleased with yourself anyway)
It took the better part of 8 hours. But...........
I have BMW throttle bodies attached to the side of the Monster motor.
THIS was the ultimate test of my patience.
The main throttle shaft was too short since I decided to match my port spacing, as opposed to keeping the BMW CtoC spacing, and adapting things elsewhere. So, starting at the back, I bolted the two rear TB's on, and slid the throttle shaft through the support bushings. I then had to cut the shaft, and make these little splicy-doos that I made out of seamless steel tubing. The O.D. of the main shaft was like .475...AKA 3/8"
Problem was most tubing was measured in OD, not ID. When you get a thin wall 1/2" (like .062) it was still too sloppy...fortunately for me I found some thicker wall stuff that was pretty close.
I split it up the middle nonetheless. I decided that cutting a line .060 out the the tubing would make it too small ID, and when using a bolt to tie stuff together,... would make it crimp that main shaft like a second skin.
You can bet that drilling those holes through the tubing, marking the shaft w/ a sharpie, and then drilling the holes through the shaft was a tedious job....and here is where you can see the hack in me....If this was a high dollar build, all of those bolts would line up perfectly...But what can I say,..........I eyeballed every one of them.
The front and rear TB's held the fuel rail on on the engine that the TB's came off of. Now that they're on the Monster's engine, they just get in the way..The bolt hits the throttle body, and that leg that you can see sticking off of the front TB...
It will get a session with a sawzall shortly.
Of other note, Now that you can see into the TB, you can see the port work that needs to be done to match the TB up to my plate..minimal grinding will blend the opening to fix that.
I'm gonna use the factory injector bosses built into the TB base...I've already made the little straps that'll hold my fuel rail in place,...easy peasy.
So,..then,....what's left before I can call this done?
A lot actualy.
I got to decide whether or not I want to get everything perfect, and weld the bolts that mount the TB's to the backside of the plate. Doing that will act as alignment dowels so that I can put the TB's back on after I clean them up, and not have to dick with getting them all aligned while gasket gook is setting up. If I do that, the flange has to be perfect..because I'll never be able to plane down any high or low areas with 12 bolts sticking up off of that deck.
But that's the plan..
Obviously, I've got some blending to do still, I have to tap the TB's for the fittings that I'll use to feed vacuum signal to a reservoir.
I've gotta build that thing too.
The TB's still have to be cleaned up after that, painted sparkly silver metallic, cleared, and then put back together.
The #6 TB is the one that'll have the TPS sensor on it. Unlike a Mustang unit, It's not calibrate-able...Hopefully, Tuner studio will let me set open/close percentages so I wont have some goofy sht going on from that.
I've got to figure out where, and how to locate a throttle bracket..and make one..
And even after all of that.....I still gotta figure out what to do about getting filtered air into the things.
Don't matter bout none of that though.....I've got 6 ITB's hanging on the side of the Monster motor.
