ok I had my 93 fox on the dyno and it only made 241hp at 5500 and 251torq is that about right for this set up, stock botton end 302 gt40x heads ported 1.7 rockers Anderson b-21 cam trick flow track heat upper and lower intake 30lb injectors 75mm t/b pro-m 80mm mass air and aod trans with a 3500 non lock up converter 373 gears
