Im wondering Blown88GT if my mystery sensor is a replacement sensor for a 94-95 GT in the 70mm housing? If so then the check engine light should stay off (theoretically). I have no codes running or stored with the mystery sensor and 70mm housing.I am unable to identify your housing. I found a similar one on eBay. Seller says:
Stock Mass Air Flow (MAF) Sensor Replacement to suit the following vehicles:
If true, housing & sensor are not compatible with your vehicle and/or A9L EEC-IV.
- 1996 Ford Bronco All Models
- 1995 Ford Crown Victoria All Models
- 1996 Ford E Series Van E150 or E250 Models with 4.9L or 5.8L Engine
- 1996 Ford Pick-up Truck F150 – F350 Models with 4.9L 5.0L or 5.8L Engine
- 1997 Ford Pick-up Truck F250 Models with 5.8L Engine
- 1995 Lincoln Towncar All Models
- 1995 Mercury Grand Marquis All Models
BTW, if you need a 55mm housing, I have some spares with no flange, just like yours. I got them from a salvage yard a long time ago. If interested, start a conversation (PM).
If so, then you would need a T4M0 or J4J1 ECU.M
And this is why I want to put a stock 55mm MAF & housing back on it.If so, then you would need a T4M0 or J4J1 ECU.
It appears that the previous owner's didn't know what they were doing.
I would ditch the MAF & housing & get something that will work properly.
Why do you think it is that sensor?The mystery sensor is a 94-95 Cougar/Thunderbird sensor. 70mm, and part number on the sensor (if it was OEM) would be F4SF-12B579-AA
Thanks so much Mustang5L5 for clearing up the mystery of the mystery housing lol! I will try to get me a F2Vxxx... Sensor for the 70mm housing hopefully that will fix my issue of it feeling flat in the upper rpms. I still don't understand why the stock 55mm housing and sensor makes the CEL come on. I will definitely try the 55mm setup (to get the codes) again as soon as the weather around here warms up and decides to quit trying to snow.The mystery sensor is a 94-95 Cougar/Thunderbird sensor. 70mm, and part number on the sensor (if it was OEM) would be F4SF-12B579-AA
http://rover.ebay.com/rover/1/711-5...0001&campid=5335821607&icep_item=253228578312
This sensor is NOT compatible with the A9x ECU. It would probably communicate with the ECU, but the values won't translate properly. I could see why the previous owner selected it though, as the 70mm housing used with it directly fits the 87-93 intake duct work. If you look at a 94-95 Mustang MAF, you need to purchase an adapter as the MAF has a 4-bolt interface to the filter housing.
The sensor electronics that do work with the A9X processor have the part number F2VF-12B579-A2A. I do not know if the electronics will work when bolted to the cougar/tbird housing, but looking at pictures online, the two housings look identical other than the MAF housing style (couplings on both flanges, vs a bolt on MAF). I'd almost be willing to ber if you put a F2VF-12B579-A2A electronics on it, it may actually work properly.
Of course, who's to say that's not what the original owner did, but without a ford factory p/n to confirm, I wouldn't trust it.
If you hope on ebay and search F2VF-12B579-A2A, you'll find a few electronics sets for under $20
94-95 Cougar/tbird MAF housing, 70mm, F4SF-12B579-AA
Vs 94-95 Mustang MAF housing, 70mm, F2VF-12B579-A2A
Studying the various pics online, it appears internally they have the same build structure, so the housings may be interchangeable. I cannot confirm this though
