- Mar 3, 2010
- 1,630
- 773
- 163
Got it that’s how I have it, I have two one too which kinda sit into that bushing on top of the boot. With the old senotracs that were in there they had it that way to but on the top they added a spacer, plus the stock cover and then the nut, don’t ask me why, think I had pep boys or someone install them at that point lol, there is a pic somewhere in here of them. Maybe it had a longer strut shaft? Idk but the new tokico blues I got don’t seem like they can use all that. I’ll just leave the top spacer out and tighten up that nut. So do I just impact it down till tight or am I suppose to use a certain torque spec? Everything I’ve seen is ppl just using their impacts and tightening.The spacer is suppose to go on top of the strut below the cc plate and no spacer under the top nut.
Idk what that little plastic peice is that is blocking it but I wanted to rip it out. So anyways back to disconnecting from the brake pedal. So is it as easy as taking the pin out and removing and pulling the booster out. Got the MC out and began to pull the booster and then remembered about the pedal part. Also got these guys in and not gonna lie with all the bs here in Austin with package bombs I was a little cautious opening. Can I paint the booster with my left over black caliper paint I used to spray the disc hub or should I use something like engine paint? Oh also so didn’t realize the connection that was under neath the stock MC which I believe is for the passenger side brake if I’m correct idk? But seems that the 93 cobra MC doesn’t have that and I’m sure I’ve seen this on the vids I watched but what do I do with that line and i know there was a reason for that brake line adapter I bought.
