97 gt pi engine swap problems
Khenji Harris
31
Had the 99-04 automatic engine swapped into my 97 manual gt at a shop and they swapped over bolt one from the 97 like long tubes, pulleys and cold air intake. Also they had to order a new flywheel for it to bolt to the automatic engine. First time driving out the shop the car seemed to be misifring especially at low rpms, but never threw a misfire code. Under full throttle it would spit/stutter and be very hesitant to go. The shop said it would need a tune because of the modifications and it being the pi engine instead of the npi. Bama sent a custom tune so it's on 87 performance however I'm running 93 octane gas. Only have been driving it tuned for a day there was a little improvement in the spitting but it's still hesitant on full throttle. Also threw codes for
Evaporative Emission Control System Vacuum System – Purge Control Valve,
Catalyst System Efficiency Below Threshold,
insufficient switching of oxygen sensor bank 1,
A Heated Exhaust Oxygen (HO2S) sensor indicating lean at the end of a test is trying to correct for an over-rich condition
Sounds like the tune is for a 00-04 and not a 97. Unless you didnt hook up those connectors, you shouldnt be getting those odd codes. Or someone forgot to plug in your o2 sensors.
Shop said there was a problem with the o2 cause they aren't far apart enough from each other, like they are both before the cat he said but that's how it was before the swap was done. I was mainly asking what could be causing the misfiring like symptoms under full throttle
ALWAYS post the full DTC's codes. There are 1,000's and they each have have a story to tell.
Please report the status of:
  • the fuel system used. Did you use the original return based fuel system?
  • Did you use the original 1997 fuel injectors?
  • Are there any exhaust leaks? Especially on the right side?
The 1997 PCM will run the PI motor. It will not however run it perfectly without a tune.
P1443
P0420
P1131
P1151
I'm not 100% sure on all the specifics that were done because it was done at a shop, he did mention that they had to swap the fuel rails or something along those lines
I didn't think that a Non-PI exhaust manifold would bolt up to a PI head. Are you positive there's isn't an exhaust leak?
  • Electrical:
    • Short to VPWR in harness or HO2S
    • Water in harness connector
    • Open/Shorted HO2S circuit
    • Corrosion or poor mating terminals and wiring
    • Damaged HO2S
    • Damaged PCM
  • Fuel System:
    • Excessive fuel pressure
    • Leaking/contaminated fuel injectors
    • Leaking fuel pressure regulator
    • Low fuel pressure or running out of fuel
    • Vapor recovery system
  • Induction System:
    • Air leaks after the MAF
    • Vacuum Leaks
    • PCV system
    • Improperly seated engine oil dipstick
  • EGR System:
    • Leaking gasket
    • Stuck EGR valve
    • Leaking diaphragm or EVR
  • Base Engine:
    • Oil overfill
    • Cam timing
    • Cylinder compression
    • Exhaust leaks before or near the HO2S(s)
  • Electrical:
    • Damaged HO2S
    • Damaged PCM
  • Fuel System:
  • Induction System:
    • Vacuum Leaks
    • PCV system
  • EGR System:
    • Leaking gasket
    • Stuck EGR valve
  • Base Engine:
    • Oil overfill
    • Cam timing
Like I said I'm not 100% sure so there definitely could be an exhaust leak, but could all those things you listed above be the cause of the misfiring symptoms under full throttle?
The DTC codes are trying to tell you that the PCM "thinks" it has lost control of the air to fuel mixture. The O2 feed back loop is broken and the PCM does not know how to correct it.
And yes any one (or more) of the items listed "could cause" the DTC to be thrown. The trick is to figure out which one.
IMO it's also naive to expect the motor to make smooth WOT power under the circumstances. In fact it might be down right dangerous to force the motor to make maximum power with outstanding DTC codes.
In general this trouble shooting should start with the misfire at part throttle. Why? Because the part throttle is where the lack of tune will have the least effect (the non-PI PCM should be able to run a PI motor assuming everything else works). Are you positive that the spark plugs wires have been correctly routed and that all factory stand offs and looms used?
Other notes. It is well known that long tube headers and O2 sensors don't always get along. Add to the mix an exhaust leak and this will make a bad situation worse.
How to trouble shoot this problem? You need data. Having a graphing ODB2 scanner might make real short work of this problem. Otherwise it's "load up the parts cannon" and start guessing.
Here's some information on an affordable Windows based ODB2 scanner with graphing capabilities.
ForScan ODB2 scanner w ELM327 USB
https://www.stangnet.com/mustang-forums/resources/forscan-odb2-scanner-w-elm327-usb.57/
Wow okay thanks man that info has been helpful, I guess I'm gonna take it to an exhaust shop to take a look at the o2 sensors and the cats and any exhaust leaks and start there
Like burns said, non-pi manifolds may not be the same size on the primaries.
What color are the injectors.
Think they are orange, always get them confused with the spark plugs
