91 2.3 convertible aftermarket installation power but no sound
This is your radio adapters. One is for power, ground , memory , dimmer, ect, the other is for the speakers. Wire your radio into it ( match the colors) . Then plug it in
Reactions: General karthief
connected the top pic harness to (aftermarket hu) to theose the conectors u mentioned then i connected yhe m to the second pic nosound
No... it’s your radio with its personal harness , wired into the adaptor harness ( each wire separated and covered with heat shrink or electrical tape) then you plug that into the car.
In the car there will be only one place the connector for the power wires will go, but there will be 2 for the speakers. You want the one that is before where the amp was.
That’s all there is... or you can completely eliminate the adapting harness by looking at a diagram or using a test light.
In case you need it, the wires coming out of your radio are
Red= switched power ( turns the radio on)
Black = ground
Yellow = constant yellow
Blue = signal for amp
Then the paired colors for each speaker.
Black = ground
Black = ground
Ok step one is building harness and adapters together
Black = ground
Black = ground
Ok step one ::::is connecting this buliding adapter harness ess and radio harness. Correct? (Pic 1)
Step 2::::is connecting power adapter. To power connector(pic 2)do i leave harness dis connected like this and connect here or reconnect and go for the power where the radio back was on harness (which is cut for some reason)pic 3
Step :::::3 is connectin to speaker adapter harness but this speaker harness is cut too as well.... do i connect some how here ? Pic4 long wires. These were plugged into the amp or do i connect to where rafio was black connector?(pic2)
Too for for me to help.
Ok. So it’s possible the speakers are no longer wired to the factory harness, so this is based on a factory set up.
Step one!! Connect these wires based on the colors!!
Nothing here is good.
