- Mar 3, 2010
- 1,611
- 795
- 163
Ok I’m gonna have to figure out where that is. Any idea what it looks like? Guess I can try and google it.Code 96 – KOEO- Fuel pump monitor circuit shows no power - Fuel pump relay or battery power feed was open - Power / Fuel Pump Circuits. The fuel pump lost power at some time while the ignition switch was in the run position.
This means you are having issue with the Fuel Pump relay. In your year model it is under the MAF, so it is exposed to hot/cold all the time. It is probably going bad, and once it warms up making it have issues.
