Still making progress, most of the "big" things to get the car at least running are now here, only thing left to buy is the fuel system, a battery, and a laptop (yes im in the stone ages and am just have a desktop that i do all my pc'ing on). So here's the rundown on whats been going on since the last update.
60lb injectors, trying to keep the wiring clean (easier said than done)
Mounted the map to the bottom of the air cleaner to try to hide it.
EFI wiring done.
Made a coil bracket out of some scrap steel, one day ill re-fab this out of a piece of aluminum.
Wiring the under the dash was a bitch. Gutted the dash harness so about half of it is gone. The trans controller is mounted to the same plate the the holley is, and all except the main power is hooked up.
Pulled the engine again to shorten the oil pump drive and install the flexplate and converter. Just using the stock v6 one right now, cant afford the custom it really needs right now, but since I havent gone thru the trans yet it'll have to come out anyway so ill just do both at the same time.
Hopefully this will be the last time its in the air until its been running for a while and i go to rebuild said trans. You can see all the EFI wiring is coming thru the trans tunnel to keep it out of sight. Only wires left to run are for the oil and temp gauges in the dash, and a fan trigger, should still be easy enough once i find my senders for those.
