I need a miracle! - Father's Day Gift Won't Start
I have a 1992 Mustang 5.0 5 Speed SSP that cranks but will not start. I followed the steps outlined in jrichkers list and I'm stumped. The car has 38 psi of fuel pressure (new walboro 255 fuel pump, fuel relay, fuel sending unit) and I have spark from the coil and also to the plugs (changed out plugs, wires, and coil from a spare set). The ECM has also been changed out (A3M to A9P) and the car did run a lot better. New TFI (up to three now), Dizzy, IAC, ECT, TPS, Battery, Ign Switch as well as other parts. I have power at the injectors (used noids too) and the pump primes when the key is turned. This car will not flash codes and I've attempted to fix this to no avail.
Before dying, the car had a habit of stalling once it got to operating temp (180) but ran perfectly this last time with the new ECM until I turned the car off and tried to restart it.
This car is a surprise for my dad who is turning 50 this year and I am gifting this car to him tomorrow. He grew up with foxes and sold his 10 years ago and never got another one.
I really would love to drive it over instead of having it towed so any advice is greatly appreciated!
(I'm in the DFW Area as well in case someone is nearby!)
Thanks!
Thanks!
Cranks OK, but No Start Checklist for Fuel Injected 5.0 Mustangs model years 1986-1995
A word about this checklist before you start: it is arranged in a specific order to put the most likely failure items first. That will save you time, energy and money. Start at the top of the list and work your way down. Jumping around will possibly cause you to miss just what you need to see to find and fix the problem. Don’t skip any steps because the next step depends on the last step working correctly.
Revised 26-Jul-2017 to add fuse link diagram.
All text applies to all models unless stated otherwise.
Note: 94-95 specific changes are in red
1.) Remove push on connector (small red/blue wire) from starter solenoid and turn ignition switch to the Run position. Place car in neutral or Park and set the parking brake. Remove the coil wire from distributor & and hold it 3/8” away from the engine block. Jumper the screw to the big bolt on the starter solenoid that has the battery wire connected to it. You should get a nice fat blue spark.
Most of the items are electrical in nature, so a test light, or even better, a voltmeter, is helpful to be sure they have power to them.
No spark, possible failed items in order of their probability:
A.) MSD, Crane, or other ignition box if present - Bypass it and return to stock configuration if possible. Do this as a temporary measure to eliminate it as a possible problem source.
B.) PIP sensor in distributor. The PIP sensor supplies the timing pulse to trigger the TFI and injectors. A failing PIP sensor will sometimes let the engine start if the SPOUT is removed. See paragraph 5A – Using a noid light will tell if the PIP is working by flashing when the engine is cranking.
C.) TFI module: use a test light to check the TFI module. Place one lead of the test light on the red/green wire on the ignition coil connector and the other lead on the dark green/yellow wire on the ignition coil connector. If the TFI is working properly, the test light will flash when the engine is cranked using the ignition switch.
D.) Coil
E.) No EEC or computer power - EEC or computer relay failure
86-93 models only: EEC relay next to computer - look for 12 volts at the fuel injector red wires.
94-95 models only: EEC or PCM power relay in the constant control relay module. Look for 12 volts at the fuel injector red wires.
Both 86-93 and 94-95 models: No 12 volts with the ignition switch in the run position on the fuel injector red wires. The relay has failed or there is no power coming from the ignition switch. Make sure that there is 12 volts on the red/green wire on the coil before replacing the relay.
F.) No EEC or computer power - fuse or fuse link failure
86-93 models only: Fuse links in wiring harness - look for 12 volts at the fuel injector red wires. All the fuse links live in a bundle up near the starter solenoid. Look for a 20 gauge blue fuse link connected to 2 black/orange 14 gauge wires.
94-95 models only: 20 amp EEC fuse in the engine compartment fuse box. Look for 12 volts at the fuel injector red wires.
G.) Ignition switch - look for 12 volts at the ignition coil red/lt green wire. No 12 volts, blown fuse link or faulty ignition switch. Remove the plastic from around the ignition switch and look for 12 volts on the red/green wire on the ignition switch with it in the Run position. No 12 volts and the ignition switch is faulty. If 12 volts is present in the Run position at the ignition switch but not at the coil, then the fuse or fuse link is blown.
Note: fuses or fuse links blow for a reason. Don’t replace either a fuse or fuse link with one with a larger rating than stock. Doing so invites an electrical fire.
Ignition fuse links may be replaced with an inline fuse holder and 5 amp fuse for troubleshooting purposes.
94-95 models only: Check inside fuse panel for fuse #18 blown – 20 amp fuse
H.) Missing or loose computer power ground. The computer has its own dedicated power ground that comes off the ground pigtail on the battery ground wire. Due to it's proximity to the battery, it may become corroded by acid fumes from the battery.
In 86-90 model cars, it is a black cylinder about 2 1/2" long by 1" diameter with a black/lt green wire.
In 91-95 model cars it is a black cylinder about 2 1/2" long by 1" diameter with a black/white wire.
You'll find it up next to the starter solenoid where the wire goes into the wiring harness
I.) Computer. Don’t replace the computer just because you don’t understand how it works. Computers seldom fail, it usually is a sensor or wiring problem that causes the problems.
J.) Bad or missing secondary power ground. It is located between the back of the intake manifold and the driver's side firewall. It supplies ground for the alternator, A/C compressor clutch and other electrical accessories such as the gauges.
K.) Engine fires briefly, but dies immediately when the key is released to the Run position. Crank the engine & when it fires off, pull the small push on connector (red/blue wire) off the starter relay (Looks like it is stuck on a screw). Hold the switch in the crank position: if it continues to run there is a problem with either the ignition switch or TFI module. Check for 12 volts at the red/green wire on the coil with the switch in the Run position. Good 12 volts, then replace the TFI.
See the Ignition switch wiring diagram for more information on the ignition wiring fuse link because it is the next thing to be tested. You will need a Multimeter or DVM and know how to use the Ohms function to check continuity between the red/green wire on the ignition coil and the red/green wire on the ignition switch. Make sure that the ignition switch is in the off position when you do the check. You should see less than 1 Ω (Ohm) between the red/green wire on the coil and the red/green wire on the ignition switch. More than 1 Ω means that the fuse link may have blown open and needs to be replaced. If you get 1 Ω or less means the fuse link is OK and the ignition switch is bad.
Wiring Diagrams:
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host) for help on 88-95 wiring Mustang FAQ - Engine Information Everyone should bookmark this site.
Complete computer, actuator & sensor wiring diagram for 91-93 Mass Air Mustangs
http://www.veryuseful.com/mustang/tech/engine/images/91-93_5.0_EEC_Wiring_Diagram.gif
Complete computer, actuator & sensor wiring diagram for 94-95 Mass Air Mustangs
http://www.veryuseful.com/mustang/tech/engine/images/94-95_5.0_EEC_Wiring_Diagram.gif
AutoZone wiring diagrams: You can navigate to the diagrams yourself via Repair Info | AutoZone.com and select the car year, make, model and engine. That will enable you to bring up the wiring diagram for your particular car.
2.) Spark at coil wire, pull #1 plug wire off at the spark plug and check to see spark. No spark, possible failed items in order of their probability: [/b]
A.) Moisture inside distributor – remove cap, dry off & spray with WD40
B.) Distributor cap
C.) Rotor
D.) Spark Plug wires
E.) Coil weak or intermittent - you should see 3/8" fat blue spark with a good coil
3.) Spark at spark plug, but no start.
Next, get a can of starting fluid (ether) from your local auto parts store: costs a $1.30 or so. Then pull the air duct off at the throttle body elbow, open the throttle, and spray the ether in it. Reconnect the air duct and try to start the car. Do not try to start the car without reconnecting the air duct.
Two reasons:
1.) If it backfires, the chance for a serious fire is increased.
2.) On Mass Air cars, the computer needs to measure the MAF flow once the engine starts.
If it starts then, you have a fuel management issue. Continue the checklist with emphasis of fuel related items that follow. If it doesn’t, then it is a computer or timing issue: see Step 4.
Clue – listen for the fuel pump to prime when you first turn the ignition switch on. It should run for 2-4 seconds and shut off. To trick the fuel pump into running, find the EEC test connector and jump the connector in the Upper RH corner to ground. The EEC connector is near the wiper motor and LH hood hinge.
attachments\68357
If the relay & inertia switch are OK, you will have power to the pump. Check fuel pressure – remove the cap from the Schrader valve behind the alternator and depress the core. Fuel should squirt out, catch it in a rag. Beware of fire hazard when you do this. In a pinch, you can use a tire pressure gauge to measure the fuel pressure. It may not be completely accurate, but you will have some clue as to how much pressure you have. If you have any doubts about having sufficient fuel flow/pressure, rent a fuel pressure test gauge from the auto parts store. That will tell you for sure if you have adequate fuel pressure.
4.) No fuel pressure, possible failed items in order of their probability:
A.) Tripped inertia switch – Coupe & hatch cars hide it under the plastic trim covering the driver's side taillight. Use the voltmeter or test light to make sure you have power to both sides of the switch
B.) Fuel pump power relay – located under the driver’s seat in most stangs built before 92. On 92 and later model cars it is located below the Mass Air Flow meter. Look for 12 volts at the Pink/Black wire on the fuel pump relay.
C.) Clogged fuel filter
D.) Failed fuel pump
E.) 86-90 models only: Blown fuse link in wiring harness. Look for 12 volts at the Orange/Lt Blue wire on the fuel pump relay.
91-93 models only Blown fuse link in wiring harness. Look for 12 volts at the Pink/Black wire on the fuel pump relay.
The fuse links for all model years 86-93 live in the wiring harness near the starter solenoid.
94-95 models only: 20 amp fuel pump fuse in the engine compartment fuse box. Look for 12 volts at the Dark green/yellow wire on the constant control relay module.
F.) Engine seem to load up on fuel and may have black smoke at the tailpipe. Fuel pressure regulator failed. Remove the vacuum line from the regulator and inspect for fuel escaping while the pump is running. If fuel is coming out the vacuum port, the regulator has failed. Check the regulator vacuum line for fuel too. Disconnect it from the engine and blow air though it. If you find gas, the regulator has failed.
5.) Fuel pressure OK, the injectors are not firing.
A.) The PIP sensor in the distributor tells the computer when to fire the injectors. A failing PIP sensor will sometimes let the engine start if the SPOUT is removed.
A noid light available from any auto parts store, is one way to test the injector circuit to see if the injectors are firing. The noid light plugs into the fuel injector harness in place of any easily accessible injector. Plug it in and try to start the engine: it will flash if the injector is firing.
I like to use an old injector with compressed air applied to the injector where the fuel rail would normally connect. I hook the whole thing up, apply compressed air to the injector and stick it in a paper cup of soapy water. When the engine cranks with the ignition switch on, if the injector fires, it makes bubbles. Cheap if you have the stuff laying around, and works good too.
B.) Pull an injector wire connector off and look for 12 volts on the red wire when the ignition switch is on.
C.) No power, then look for problems with the 10 pin connecter (salt & pepper shakers at the rear of the upper manifold).
attachments\610738
The injector power pin is the VPWR pin in the black 10 pin connector.
D.) No power and the 10 pin connections are good: look for broken wiring between the orange/black wire on the EEC relay and the red wire for the 10 pin connectors.
E.) TPS voltage exceeds 3.7 volts with the throttle closed. This will shut off the injectors, since the computer uses this strategy to clear a flooded engine. Use a DVM, a pair of safety pins, and probe the black/white and green wires to measure the TPS voltage.
On a 94-95 Mustang, probe the black/white and grey/white wires to measure the TPS voltage.
It should be .5-.1.0 volts with the key on, engine not running. Note that if the black/white wire (signal ground) has a bad connection, you will get some strange readings. Make a second measurement using the battery post as the ground to eliminate any ground problems. If the readings are different by more than 5%, you may have a high resistance condition in the black/white signal ground circuit.
6.) Spark & fuel pressure OK.
A.) Failed IAB or improperly set base idle (no airflow to start engine). Press the throttle ¼ way down and try to start the car. See the "Surging Idle Checklist for help with all your idle/stall problems.
B.) Failed computer (not very likely)
C.) Engine ignition or cam timing off: only likely if the engine has been worked on recently. If you removed the distributor, there is a good probability that you installed it 180 degrees out of time.
D.) Firing order off: HO & 351 use a different firing order from the non HO engines.
HO & 351W 1-3-7-2-6-5-4-8
Non HO 1-5-4-2-6-3-7-8
E.) No start when hot - Press the throttle to the floor & try starting it, if you get this far. If it starts, replace the ECT.
F. ) Engine that has had the heads off or valves adjusted. Do a compression test to make sure the valves are not adjusted too tight. You should have a minimum of 90 PSI on a cold engine.
Reactions: 88-90ConVerts
Could it be something as simple as you put the firing order backwards or 180* (or otherwise significantly) out? I mean it really sounds like you've hit everything.
It always comes down to 3 things: fuel, air, and spark. Air and spark aren't that hard to test directly.
And did you say the computer isn't giving any codes at all? Not even 11?
Reactions: GalacticPonage
General: i had the same thought of it being a great father/ son project. I tried the starter fluid in the throttle body and no dice.
Fast: I triple checked the wires on both ends of the cap and plugs and everything matches up. I did make the the mistake of taking out the old dizzy without noting the position of the rotor, but I was able to find instructions on how to find tdc and align to the crank mark and pointing the rotor at plug 1 so I think that’s correct. I had the same thoughts of just simplifying the basics of fuel air and spark so I’m lost on why this thing won’t start.
Jrichker: I replaced the IAC and TPS as well. I did discover that I don’t have a wire in my ECM harness for pin 46 and the car came with a A3M when I got it. Is this normal?
Well hell... You need a timing light. You can't dial in timing without one. Also, how did you find TDC? There are 2 TDC's for every 1 spark. Are you 180 out? And, you went counter clockwise with the wires, right?
Reactions: General karthief
First of all, as a fifty plus dad, you've done a nice thing. Running or not, he will love it.
In the list at Step 3, it says if it won't start with starter fluid, then it is either the computer or the timing.
Happy Father's Day to all.
Remember the "it ain't got no gas in it" quote? I'd bet that 80% of the time threads like this come up, it ends up being one of the simple things like has already been said. It happens to every one of us at some point. Nice car and nice gesture.
Fast: I have a timing light, but I was under the impression I couldn’t set timing until it was running? I turned the engine by hand until I felt compression on the #1 plug and checked the balancer off the crank to make sure it was at 0 (it was already marked with a white line). I do have a timing light handy. When you say counter clockwise with the wires, what do you mean?
I followed the firing order that was in jrichkers checklist off the dizzy and made sure they corresponded to the wires on the plug. Did I miss a step? (First time replacing a dizzy so this may be my issue)
General: You’re 100% right which is why I’m pulling my hair out over here because I know it’s something simple I’m not seeing. What’s your method to make sure you have the dizzy in the correct position?
JHP: Thank you and I hope he appreciates it! He had one about 10 years ago and sold it for family needs. He’s always had them so he truly deserves it.
Thank you all again for your help! This site is great and the amount of work you guys invest in troubleshooting these cars is greatly appreciated.
The A3M has the same pinouts as an A9L or A9P
Computer wiring harness connector, wire side
Computer wiring harness connector, computer side
Jrichker: Thanks for the diagram. After taking a look, I’m definitely missing a wire on the harness side for pin 46. I checked the back of the harness just to be sure and it’s not there. I think I saw in one of your checklists that wire 46 grounds a lot of sensors on the engine. Here’s a pic of the connector. Thoughts?
629457
The pin 46 thing is odd. It can't be just missing as it would take a to of work to fully remove that wire. Could it have just pulled out of the connector?
Was the car originally a manual? If so the whole A9P thing is confusing as to why it would have a auto computer in it. Also the O2 sensor harness is wired differently for a auto vs manual computer. Can you verify which way the the harness is wired?
First, before I pull the distributor out I mark where #1 plug is on the distributor side, I also take a sharp chisel and mark the distributor base and the engine block where the base sits so I know where everything goes back.
Here is how I install a distributor: I pull all the plugs, makes turning the engine over by hand easier, I hold a finger over the #1 plug hole and crank the engine with a screwdriver on the solenoid, when I feel air coming out stop and stick a screw driver in the plug hole, turn the engine by hand till the piston stops going up, you may have to turn it back and forth to get it at the top of the stroke. You balancer should be at or damn near 0*. If you marked the distributor at #1 terminal point the rotor at that mark, look at the gear on the distributor, they are at an angle, that means you will have to move the pointer back (I believe counter clockwise?) And as you stick the distributor in you will notice the rotor move as it engages the teeth on the cam, you may have to 'wiggle' the rotor a little to engage the oil pump shaft. On my car #1 was about the 1 or 2 o'clock position on the cap. The car will start at 0* and then let the engine heat up then set your timing at 10 or 12* with the spout out. Shut the car off and install the spout.
Note: every time you disconnect the battery for a length of time the computer resets and must learn a few things as the engine runs so don't be surprised if it is a bit unruly for a few minutes while it converts imput from the sensors.
It is very easy to get it one tooth off so you may have to go at it a couple times to get it at #1
Let us know how it goes.
I just meant that the firing order of he wires on the dizzy 13726548 should be in counterclockwise order. Sounds like you did it right setting the distributor over to 1 at TDC at the end of the compression stroke. And yeah, I'm dumb, you need to get it started for the light. TFI is plugged back in?
I know you said you'd replaced the TFI module and are on your 3rd. What kind of paste did you use? The issue with it dying when warm does sound exactly like a TFI module problem to me.
Dan: I think Saleen just addressed our error. I didn't notice the red marking on the harness in the picture that jrichker posted as I was following the "wire/computer side"description. We should check to see if there is 12v going into 46, correct? If there is 12v, then we have a grounding issue? Also, the car came with a A3M when I bought it (the car is 5/92 dated on the VIN Sticker). Factory 5 speed V8 car. The capacitor was blown and burned the board so I bought a A9P as a replacement.
The O2 harness has the loop wire like this example("*" = wire, "J" = jumper wire) :
|***J|
|**J |
We are going to verify this layout to be sure. I also put pictures of the blown A3M below
General: Awesome. Thank you for the walkthrough and thankfully I did these exact same steps. My dad received the car yesterday and triple checked that the dizzy was installed correctly.
Fast: You got it. The wires on the dizzy are installed in that order and a TFI is back on the car. My dad and I ran them to Autozone to have them test them and we got one bad one (old unbranded one that was on the car) and two good ones (New MSD TFI and New Motorcraft). We put the Motorcraft one on and still nothing. We used the paste that came with the MSD one (white paste?).
My dad took a look at it yesterday and he noticed that the spark is there but very weak. We are working backwards to see what's causing it since everything is pretty much new on the ignition system. He pulled the new computer today and noticed that a capacitor blew on the A9P. We're going to get that fixed and replace the other ones. Definitely going to go through the wiring and grounds again to ensure nothing is causing this as it was perfectly fine when I bought it a few days ago and the car ran great with the A9P before not restarting. Wondering if this was caused by all of the cranking.. I will report back!
Hope you guys had a great father's day! Dad really loves the car! Caught him completely off guard lol
|***J|
|**J |
THe one thing I notice is that your using a 9AP which is for an automatic being that the car is a factor manual this may be a problem with the 02 sensor and could cause the capacity to blow. I would use a A9L which is correct for a manual. Since you went through all the steps which looks good this is the only thing I see that could be a problem. I hope this helps and I'm glad your dad likes his Foxbody coupe!
Reactions: Mustang5L5
