Gots me a 351 Cleveland
mattbaker302
25
texas
howdy, I just bought myself an early Christmas present! a 351 Cleveland. I believe she's from a 73 cobra but I am not 100% certain. I'm wanting to make some power, what kind of pistons would yall recommend to me? it's already bored .30 over and staying like that. I'm also not sure about what cam to run? its got some kinda mild comp cam in right now but I'm wanting a big mutha thumpa! it is a street application tho :( so gotta keep it on pump gas.
More specs n stuff: stock heads, stock intake, stock crank, upgraded valves n valve springs, stock rockers, screw in heads studs.
I've never messed with a Cleveland so feel free to give as much advice as you wish, id appreciate it
id like around 400-450 hp... it came stock with 300
Reactions: 2Blue2
ok my advice on building the 351c is:
1: first dump the stock heads, even inf they are 4v heads, as there are much better heads on the market now. this big issue i have with the stock heads are the big open chambers, unless you have an early set of 4v heads that are closed chamber, if that is the case then keep them. the edelbrock 3v head will do nicely on the street.
2: since you want a streetable compression ratio, stick with a good flat top piston
3: convert to a roller cam, something like the comp cams xe282 cam, or similar. here is a cam i selected for you that will make power and still be streetable;
if you dont like that cam, feel free to change the parameters selected. they suggested a magnum series cam.
4: since this is going into a truck i would suggest using the performer rpm air gap intake, and top it off with an edelbrock thunder series 750cfm carb.
5: a nice set of big tube 4-1 headers and a inimum 2 1/2" dual exhaust system
i think this combination will make the hp level you are wanting easily.
Reactions: mattbaker302
hey, thanks, for all the advice. I've never even considered switching to a roller cam. if i didn't switch to that and used flat tappet hydraulic, do you think i could achieve the same power or close? also, how can i tell if the heads are closed chambered? they have the upgrade springs and the screw-in studs.
i do have the closed chamber heads.
Reactions: 2Blue2
Look on some of the Cleveland websites. The weak point is the oiling. There are some easy D.I.Y. mods to improve the oiling system.
The later Cleveland's retarded the cam timing so make sure you get the timing set from a 69 or 70. It as a standard swap when I worked in Ford dealerships in the 70's.
the advance curve on the later Clevelands were for emissions and not performance
the weak point is the oiling system, but only when the RPMs are turning over 8000 which he wont be doing on the street.
Reactions: 2Blue2
