My suggestions?
Check the fuse under the hood. If that pans out, remove the plug under the seat and check with a meter for voltage. If you have 12v there, then likely the seat base is faulty, or the gears are broken.
Used seat bases are around $100 on ebay. So if Ford wants to charge you $500+ or so to install one, i'd pass and do it yourself...if you can.
