351w swap help
Thanks man I’ll have to look into this bc if I could save on running my current long tubes that would be great. Also on the flip side what would be the down side of that 1.5in drop if any on a street car?
Your long tube header collectors and oil pan should be 1.5” closer to the pavement. Check for clearance first.
Found my list of things!!!
427ci Ford Small Block
Cylinder Heads are 210cc Pro Comp Aluminum
60cc Chamber, 2.020 In valves (severe duty), 1.600 Ex valves (severe duty)7/16 rocker studs, 10 degree machine keepers, 10 chrome moly retainers, 1.460 dia valve springs.
351w Ford Engine Block - A Ford Roller Block Was Used.
Block was square decked
Block was line honed
Block was square bored and honed with honing plates
Engine was trial assembled twice
Lifter bores are honed
427ci Ford Parts List Break Down
Forged Wiseco pistons .040, File Fit rings .040 over, Clev H series std bearings, 4340 steel 4.170 stroke crank 28oz, SIR 4340 rods 6.200infloated, ARP Main Bolts, Felpro Rear main seal, Brass freeze plugs, Durbond Cam bearings, Trickflow Hyd. Roller lifters, Double roller Timing set, Mellings oil pump pickup, Mellings Oil Pump, ARP head bolts, A complete gasket set, Oil and Filter 15-40w, A Foxbody conversion rear sump oil Pan, Stage 2 trickflow roller cam, Harmonic balancer 4 bolt, A set of 1PC Pushrods, A Aluminum Timing Cover, Trickflow 1.6 roller rockers
Intake Trickflow TFS-51511006 Upper and lower 90mm with 3/8 spacer.
Speed Density, Microsquirt PnP
Swap AC /PS bracket
47lb Injectors using EV6 adaptors
90mm TB Accufab
High flow water pump
BBK fuel rails.
Delete - EGR, Char can.
3G alt
High-Performance TFI (Distributor already has one. This is an extra one...perhaps not needed).
Trick Flow Valve covers
Wires
Plugs
Wire separator - black
Vac. lines (Tree to wall plus PCV)
Battery
Starter Solenoid
Rad (3 row with dual fans)
255 lph in tank fuel pump
Russel fuel lines
BBK shorty headers
McLeod Street Extreme clutch (700 hp rated)
TKO trans
Clutch fork
Rear main seal
BBK cold air intake
3 inch cowl hood (Tru Fiber)
hay 460 you said stock hood fit but your list states 3 inch cowl hood? What gives?
