extra_stout
5 Year Member
This must not be water tight. On my 66 I even had no cover or something, it was just open. No problems with that.
Will the sheet metal bolt nicely to the bellhousing, if you leave the rubber away?
Regarding the wear on the hydraulic lines at the hole: cut up a piece (2-3 inch length) of rubber hose in length direction and fix it with a hose clamp to both hydraulic lines.
