8 864eyed Member Nov 1, 2021 11 3 13 Macon Mar 17, 2022 #1 Mar 17, 2022 #1 Any idea what would cause vibration from T5 in 5th and only in 5th no matter the speed?
revhead347 Apparently my ex-husband made that mistake. 20+ Year Stangneter Jun 14, 2004 9,289 1,632 214 Acworth, GA Mar 17, 2022 #2 Mar 17, 2022 #2 I'm thinking pretty hard on this one. The 5th gear cluster is in the tailshaft casing. Possibly a bad bearing between the main case and the tail case. Kurt
KRUISR 10 Year Member Apr 16, 2015 1,798 903 143 Mar 17, 2022 #3 Mar 17, 2022 #3 How is you pinion angle at the transmission?
ChaseRoads do I need to lube this area? Oct 29, 2020 220 73 38 midwestern america Mar 18, 2022 #4 Mar 18, 2022 #4 you sure it's the trans and not a tire out of balance?
8 864eyed Member Nov 1, 2021 11 3 13 Macon Mar 18, 2022 #5 Mar 18, 2022 #5 revhead347 said: I'm thinking pretty hard on this one. The 5th gear cluster is in the tailshaft casing. Possibly a bad bearing between the main case and the tail case. That sucks. I'll try to get it pulled and get it looked at, thanks Click to expand...
8 864eyed Member Nov 1, 2021 11 3 13 Macon Mar 18, 2022 #6 Mar 18, 2022 #6 KRUISR said: How is you pinion angle at the transmission? Click to expand... Not sure, I'll check it when I can though.
8 864eyed Member Nov 1, 2021 11 3 13 Macon Mar 18, 2022 #7 Mar 18, 2022 #7 ChaseRoads said: you sure it's the trans and not a tire out of balance? Click to expand... Tires are new and balanced.
