M marystang98 New Member Jan 5, 2022 4 0 1 NORTH LITTLE ROCK, AR Oct 14, 2022 #1 Oct 14, 2022 #1 installing t56 trany in 78 stang. Keeping original cable drive speedo. Going to try Cable x box from Abbott Enterprises. Hear good results and been around awhile. Anyone ever use it or have any thoughts on it. Thanks!
extra_stout 5 Year Member Aug 27, 2018 826 942 113 Germany Oct 14, 2022 #2 Oct 14, 2022 #2 marystang98 said: Cable x box from Abbott Enterprises Click to expand... Why? I thought the T56 can be used with a speedometer cable...
extra_stout 5 Year Member Aug 27, 2018 826 942 113 Germany Oct 14, 2022 #3 Oct 14, 2022 #3 Speedo Driven Gear, Ford T5/T45/TKO/TKX, Magnum, 17 tooth White Check out the deal on Speedo Driven Gear, Ford T5/T45/TKO/TKX, Magnum, 17 tooth White at Modern Driveline, Inc. www.moderndriveline.com you can use just the existing speedometer cable (C4,T5,T56 etc have the same provision). At least I used it for my T5 swap... Reactions: 2Blue2
M marystang98 New Member Jan 5, 2022 4 0 1 NORTH LITTLE ROCK, AR Oct 14, 2022 #4 Oct 14, 2022 #4 extra_stout said: Why? I thought the T56 can be used with a speedometer cable... Click to expand... What I was told. Not much on the mechanic side. Thanks I see
