new crossmember mounts welded in or just a new crossmember mount? I'm new to some of the trans lango as I've only removed one when I disassembled my wrecked 95 and when I put the engine in the 94 the trans was already in place.I believe so, but not positive. I thought I read you had to modify it slightly. You'll need a new mount anyway, and I was so far into it I wasn't going to skimp on the old crossmember and just bought the Stifflers.
ok too easy then if the stiffler one is a direct bolt up I'll just go with it....I " think" the stock one works with a new transmission mount... I could not use mine as it was a for a single exhaust..
The stiffler one fits really nice.. Its small and up out of the way...
I did not have my exhaust on, so I bolted up one side, then I swung it up and bolted on the other side and the bolt holes for the transmission lined right up... Kinda like things are supposed to work....ok too easy then if the stiffler one is a direct bolt up I'll just go with it....
thanks for the pic and my exhaust will be off as well.I did not have my exhaust on, so I bolted up one side, then I swung it up and bolted on the other side and the bolt holes for the transmission lined right up... Kinda like things are supposed to work....
There is a " kit " sold for this which is nothing more that two very thick plastic bushings that lift the transmission up a bit for driveline alignment... I have one installed on my car but from what I can see it might vary from car to car.... Found a decent pic of mine installed with a TKX...
yeah i'll likely use the stocker if the 3550 doesn't have any issues that isn't too expensive to repair but if I have to buy a Tkx I'll go with the stifflerStock double jump cross member will work with the 3350. I used a stock double jump from a Mustang in my T-Bird with an early TKO with zero issues.
I will say that the Stifflers piece is waaaaay nice and like Limp said and showed it takes up a lot less space. If I do a T56 in the Bird that’s what I will use.
I tried to find one to attach here but I failed... The Kit is like five bucks, so not a real big deal...thanks for the pic and my exhaust will be off as well.
in post # 24 though Sparky said the kit is needed since the T5's is higher or something
Post number 24 sparky attached a linkI tried to find one to attach here but I failed... The Kit is like five bucks, so not a real big deal...
What can I say.... I will say when I saw prices of metal skyrocketing after November 2019, I started to buy some things I wouldn't be needing for a while and saved alot of money... Perhaps this spacer kit was one of them? LOL@limp still thinks in 1980 dollars
About tree fiddy at tractor supply for grade 8 hardware . Holly's even worse with map pricing of $60 for scrap aluminum block with 2 holes drilled in it for there TKo/TKX spacers.. Most people don't even check the drive line angles, those spacers are close. Hell I've used fender shims before lol.
Those were good days, not as good as the 70's but close........@limp still thinks in 1980 dollars
